YOKOMO Touring Car BD-8 >
Like Tree125Likes
Old 03-09-2017, 08:26 PM
  #391
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by 190mph
Is this Ben from Ottawa area?
I think you just grab a BD7 front spool drive cups from the BD7 2016 which is D-046
96T spur is the way to go I found to cover you and you need to grab the Option Top Deck B8-003NB to allow bigger pinions for the stock classes gearing FDRs.
As for a chart you might have to find some program that spits out an excel table after inputting your 1.7 internal drive ratio.
I prefer to run the largest spur possible to attain the ratio I desire. it is my opinion that the car accels easier and as increased natural braking might also help with that pesky stripping issue some of ya'll are having that I'm not
skypilot is offline
Old 03-14-2017, 01:40 PM
  #392
BardSmith's Avatar
Trader Rating: 64 (98%+)
I will be posting a BD8 2017 Aluminum kit for sale on the national thread soon. Used on carpet only. Comes with extras and spares. Pics to follow. Hit me up if interested.
MontanaMaxx likes this.
BardSmith is offline
Old 03-19-2017, 10:22 AM
  #393
Can anybody tell me, what will give bump steer changing?
B.S. is offline
Old 03-19-2017, 01:40 PM
  #394
AL1983's Avatar
I'm looking for alternative adjustable body mounts. The O-ring on the Yokomo ones are on the outside and crack/break easily.
Xray ones are the best, pretty tight, but don't fit the Yokomo body post holes.
Any one?
AL1983 is online now
Old 03-19-2017, 02:00 PM
  #395
Trader Rating: 90 (100%+)
Any one?
Use Xray body posts and then you can use the Xray adjustable body mounts.
RBLove is offline
Old 03-19-2017, 02:48 PM
  #396
Migigu's Avatar
2# more shim, more in corner steering.😉
Migigu is offline
Old 03-19-2017, 04:57 PM
  #397
b20btec's Avatar
Arc adjustable posts are the best. Made out of plastic and is wider, had a set for two years no issues.
AL1983 likes this.
b20btec is offline
Old 03-20-2017, 06:57 AM
  #398
fpart's Avatar
Trader Rating: 41 (100%+)
I just picked up a BD8. It ran just as fast as my xray T4 17 without any setup changes, nice. However, I had a couple observations:
1. when I push down slightly on the rear belt. I see that pulley area of the motor mount flexing back. Is this normal?
2. I guess I should have know this but the pulley cams move under load unless you put set screws in the inner link mount on the top of the bulkhead. With aluminum cams, do you have to do this with set screws or not?
Also does anyone had a good setup for black carpet indoors I can use for starters?
Thanks! The car is nice!
fpart is offline
Old 03-22-2017, 04:32 PM
  #399
Where you have the Cams as Aluminum?
190mph is offline
Old 03-22-2017, 05:01 PM
  #400
fpart's Avatar
The cams are plastic. But I just ordered aluminum.
fpart is offline
Old 03-22-2017, 05:04 PM
  #401
Where can I get some? I noticed when I tighten down the grub screws to make sure they don't spin around on me it seems to affect the free spin on the whole drive train as it pressures the bearing.
190mph is offline
Old 03-22-2017, 05:10 PM
  #402
fpart's Avatar
I ordered them from amainhobbies.com
https://www.amainhobbies.com/yokomo-...8-btcb/p540901
fpart is offline
Old 03-22-2017, 05:22 PM
  #403
Cool thanks! 1 per package is interesting.
190mph is offline
Old 03-22-2017, 07:22 PM
  #404
veecee's Avatar
Trader Rating: 34 (100%+)
The aluminium diff cams won't necessarily eliminate the spinning. Best thing is to use a little threadlock in the grub screw and just nip it down slightly on the cam. That's what I have done with the standard plastic cams and they've never moved on me in 13.5 blinky. Otherwise use the BD7 plastic holders and they definitely won't spin.
veecee is offline
Old 03-22-2017, 07:29 PM
  #405
b20btec's Avatar
The aluminum diff cams are trash, they will spin on you, stock plastics are the best.
b20btec is offline
