Xray T4'17
#1096
Just had another look at the car yesterday and also checked the rear diff and re-filled with a little more oil (3000). The rear diff feels tighter now. Could a rather loose rear diff be responsible for the oversteer? I always thought the thicker the oil the more oversteer I would ultimately get.
#1097
The rear one was pretty tight. I tried to loosen it up but even on the loosest settings it feels somewhat tight.
#1099
Opposite for moving chassis backward (arms forward), more weight to the rear. More rotation and more steering.
HiH
Ed
#1102
#1103
Just to give an update with my issues. It works now after changing the roll center in the back I had nice grip and a very funny race day. Thanks again for all the tips and hints.
To elaborate a little bit here. What did I change from the stock asphalt setup?
- Rear shocks were moved one hole to position 3.
- I changed the shims under the rear camber links to move the roll center further down. I initially replaced the outer 4mm shim with a 3mm one. This already improved the stability of the rear a lot BUT during the run it started to oversteer again mid corner. I then replaced the inner 1mm shim with a 2 mm shim and this resulted in well behaving rear throughout the whole run.
#1104
Anyone have a good outdoor setup with the aluminum flex chassis on medium grip asphalt??
#1105
Chassis Protector
Who makes a good chassis protector that is precut for the carbon chassis? Preferably stateside if possible..
Thanks..
Thanks..
#1106
I am seeing a local guy do really well with the aluminum flex chassis on almost a kit setup on medium grip asphalt. The only changes he has made is adding screws at the layshaft, running the graphite center brace with all the screws, running all the screws in the motor mount and going to 5k in the rear diff. Nothing really fancy and the car is hooked up.
#1107
Running the brace and all the screws..... that's makes the chassis stiffer? I thought the benefit of typical carbon chassis setup on asphalt was better because of more flex?
#1108
#1109
Even easier, roughly cut a piece of material that will cover the chassis, stick it on, press firmly to make sure the foil is well and truly attached all around and especially around the edges where you will cut, and then with a sharp knife or a scraper blade cut carefully around the chassis and all the cutouts. It is best if you rest the blade perfectly perpendicular to the chassis. Use a brand new blade and it will cut like butter.
To cut the holes around the screw heads, use a die punch of correct size and push it firmly against the foil, and twist a little bit, taking care not to move sideways. Or just push through the foil a hex driver and back off the screws enough to lift the foil around the heads, and then cut with your scalpel by using the the screw head edge as a resting guide for the blade. If you have a die punch that fits fest (snug) around the screw head, you can push that against the raised head and the punch and the screw head will cut the foil in between like a guillotine. This is the easiest and best way to do it, but relies on having a die punch which is a perfect fit. I have used brass tubing to make my own dies on the lathe by cutting a chamfer on the outside of the tube until the inner lip has a razor sharp edge. It wears out, but then again, I can easily re-sharpen it and there's no danger of damaging the chassis if I slip up.
I actually cut the screw holes only when I need to take out a screw for maintenance, so some never get cut over the life of the protector foil.
This is going to give you a perfectly formed protector every time.
Lately, what I do is actually use two pieces of foil, usually the rear quarter of the chassis is a separate piece. The two parts are separated by a straight line running across the chassis. This is only to allow me to change just the rear quarter when it gets scraped up and nasty, so I don't have to change the whole sheet.
I use the AE sheets and with the two piece technique I can squeeze two chassis protectors out of it.
You can also use a four piece technique, by splitting the chassis into four parts with a second, longitudinal line. This makes it even easier for later replacements and gives better use of the available sheet.
Or you can divide the chassis in as many parts as you want, depending on where you know the protector will wear and will need replacement. Your imagination is the limit.
Another protective measure I use is to take out the two screws at the very back edge of the chassis before I put the rear foil on (usually these screws hold the rear suspension block) and re-insert them through the foil. This means their heads will be proud of the bottom of the chassis, just enough that the screw heads get scraped on the track rather than the rear edge of my carbon chassis. Needless to say, these two screws are never replaced by titanium. Steel screws are cheap, chassis plates and titanium screws are expensive.
I have also used very thin (0.1mm) polycarbonate foil stuck to the chassis with carpet tape. It holds up unexpectedly well, and it is a lot cheaper. The covering technique is the same.
#1110
Yep, his car is very good. More flex isn't necessarily more traction. The car can flex too much. In his case he has removed nearly all flex and it seems the stiffer he goes the better it gets for the time being. I will say though, others have tried the alum. flex chassis at our track and did not feel the same result, so it could be driving style and as always, the rest of the setup will have an effect as well. Some of our guys like aluminum, some don't.
