JRXS Rubber Tire Carpet Setup? >
Old 12-31-2005, 12:07 PM
Trader Rating: 13 (89%+)
Default JRXS Rubber Tire Carpet Setup?
any have a good setup for either the Vegas IIC Track or a high bite carpet track - semi techincal.
rcscrewz is offline
Old 12-31-2005, 03:00 PM
look on page 316 of the JRXS thread...its like the 4th post down
R/C Anonymous is offline
Old 12-31-2005, 07:03 PM
Yeti35's Avatar
Newman setup minus the spool was the setup I used at IIC. It worked great but the driver needed some work.
Yeti35 is offline
Old 01-01-2006, 07:40 AM
Do you mean newmans setup for asphalt? where can I find this setup sheet
rcscrewz is offline
Old 01-01-2006, 08:47 PM
Yeti35's Avatar
http://www.teamlosi.com/pdfs/setups/JRXS/A3.pdf Here you go. Like I said, the only thing I did not use at IIC was the spool, just used diffs front and rear.
Yeti35 is offline
Old 01-01-2006, 08:54 PM
Trader Rating: 16 (100%+)
FYI...I could never get the Numan rubber setup to work effectively on anything other than high bite situations...outdoor ashphalt or indoor carpet.
Still Bill is offline
Old 01-01-2006, 08:56 PM
i ran the Numan setup on my JRXS on low and medium bite carpet with tons of changes but i did have a spool in it and it was quite fast
Old 01-01-2006, 09:54 PM
beerbarron's Avatar
What happened to the XXXS?
beerbarron is offline
Old 01-01-2006, 11:07 PM
Juan Valdez's Avatar
Here's what I ran Saturday (made the A-main with it):
Front:
Low Roll Center, Arms flat
0 deg Front Pivot Block
4 deg hubs
17.5 lb springs
50 wt. Trinity oil
57 piston
Shock top - Inside hole
Shock bottom - BK bracket
Camber link: Bottom on tower (hole #1)
Diff Height - Low
0.050 sway bar
Front diff, 42 tooth pulley
Droop 3mm over ride height
Rear:
2 deg Rear Pivot Block, 0 deg Standard hubs
12.5 lb springs
40 wt. Trinity oil
57 piston
Shock top - 2nd from inside (hole #2)
Camber link: 5-A
Diff height - High
0.040 sway bar
Chassis posts were removed
Parma Alfa body
stock motor
Take-Off CS27 Promounts (spec tire)
The set up is a work in progress, but it seems to work best with a relaxed driving style. Don't run it into the corners too hard or it'll push. I want to get more initial steering yet, so I'm going to try a 1 or 2 deg front pivot, and 6 degree front hubs.
Anyway, just thought I'd throught it out there since I don't see to many rubber tire/carpet setups around. If anyone actually tries it, I'd welcome feedback/suggestions.
Juan Valdez is offline
Old 01-03-2006, 12:13 PM
Super Moderator
roadrashracing2's Avatar
Just bought a few rubber tires $25 new set.
roadrashracing2 is offline
