Schumacher Mi6/Mi6 EVO
#76
i will be driving mine again on sat night under the lights on an outdoor asphalt track. looking forward to driving it.
#78
#79
See the Xray threads...
#84
Maybe they've not yet got it working well enough.
But the mi5evo was used by a Schumacher UK driver at the Cotswolds national recently. Although they'll have you believe it was an mi6
#86
You would also need to run the new belts. The new rear diff is the same as the evo diff with a shim added to take the play out of the new 3mm belt. The new spool only fits the new belt. I haven't looked at how the belt alignment would be with layshaft gear close enough but i am guessing that it should work/
#87
I think Harper has run it in the Mi5
From the first race of this years ETS season.
