TT-01 Forum
#841
... the TT-01 is a capable racer in the silver can category, but the need for hop ups (= better road handling) depends on the track. ... I would settle for bearings, oil shocks + set of springs, camber adjustable front suspension, tyres and FDR 4.2. During hot weather I would also use a motor heat sink.
Ok, well see! I just put in a 8.5T brushless (20T/61) and tested in on my street; woah it's fast. Handling seems ok but won't know till I can test it on Sun at the track. Won't be allowed to race with that motor, but I hope I can get some testing in.
#842
True, Aliso is a pretty wide open flowing track; it had a couple sharp 180's and that's where the car had the worst bounce. Going to try it on Sun on a more technical track.
Keep in mind, my reference is for foam on carpet. Rubber on black top may be an entirely different situation.
I am waiting for the snow to melt to get the car out on the driveway for a bit.
#843
I love that - we have 30 degrees C in Melbourne (Australia) and have never received snow! My biggest problem at the track is to keep the flies away and not to get sun burnt. I have crashed more than once when swatting away a fly that is trying to crawl up my nose whilst the car is going at top speed. Since then I resort to industrial strength fly repellant. My wife gave me a bug zapper too that I wear around my neck. It sounds like a mosquito
#844
Crazy weather here over the past few days....8" of snow, then 3" of rain, 60 degrees F, tonight another 3" of rain. It is supposed to be 45 today, this morning is was 21.
In the summer we get the same issues but with mosquitos!
#846
Looks neat. Where do you power the fan from? Main battery?
#847
overheating problems...
19/61 would still make my esc like a toaster.
i'm planning to get lowest pinion. and highest spur gear possible.
if need to use an adapter for different brands...
any suggestion what parts to use?
spur gear adapters works with tt01?
#848
when i had the stock teu esc and motor. i parallel wire the fans on the main battery.
this fan is from pc fan (requires 12v) still good air flow.
when i hooked up the mamba, i have a separate lipo batt for it.
i switched it back to stock esc unti i get a better gearing on the mamba to avoid over heating.
#849
i just got my mamba esc and 7700 motor.
You are in the right range, if you are that hot you should probably check for binding. It won't take much, I had a shim in the rear diff to move the diff pinion away from the bearing and it was rubbing too much against the diff spur, charred my silver can wires and temped at 190+ degrees at 5.7 fdr; took out the shim and the motor was about 130 degrees at 4.8 fdr. This weekend ran a 8.5 turn at 7.9 fdr (20/61) and it didn't get hot.
You need to go custom with a spur much larger than 61, the gear cover will get in the way and you'll want more of a slider for the motor with the smaller pinion.
#850
Reedy's 3-star was a 7700kv 6.5 Turn brushless. The manual said to gear touring cars at 8.2 for long tracks and 9.4 for short. With a 61 spur that would be a 17-19 pinion, and most guys gear faster than what the manual recommends.
what do you mean by BINDING?
what do you mean by CHARRED your motor?
and are you referring to the bearing near the drive shaft? or the diff left and right?
and if go to stock 19/61 - i'll be fine?
#851
Overtightening the wheels can deform the plastic and cause drag, any part where friction is caused. The TT-01 drive train can be very smooth and free, if it isn't it's going to cause the motor to work harder and heat up.
This was just a thought on why you might be running hot because the gear ratio doesn't sound out of range. If this isn't clear or solving the problem have guys at your track take a look.
#852
Just make sure that everything spins freely with no rubbing of parts to drag the motor down. Take out the motor and spin the drive shaft or roll the car; without the motor the wheels should spin and spin and spin.
if gearing is ok then, above mentioned should solve this...
back to the FM. should i change to FM system?
#853
You won't run into a lot of glitching problems that happen with AM. When I drive under a power line, sometimes my car veers off to the side.
Okay guys I have a dilemma. I love the TT-01, but then there's that desire for the parts and stabilizers and carbon upper frame and all that jazz... and I don't know if it would be better off to just get another chassis like a used TC3 or a Pro 4 for less than I would be buying in extras.
Right now, my chassis is a second hand one, and the drivetrain is having issues, and I think it is coming from the bearings. I thought about getting new bearings and maybe CVDs, and thought about all the wheel wobble that is going on...
I don't know if it is worth it to overhaul my chassis, or to just get another one. I know it would be more fun to overhaul mine, but things like bearings and cvds and aluminum knuckles aren't cheap. And in the end this will cost more than picking up a used Pro 4. PLUS I was looking into getting a brushless system, but before I do that I want to fix the drivetrain problems with this one.
...what do you guys think?
#854
I have a TT-01 and TRF415 and I prefer to drive the TT-01 simply because I can do it anywhere: on the street, in a parking lot, etc. I don't have to worry about settings, chassis tweak, etc. There isn't that consistent need to cringe when the inevitable crash happens. I have a TA-05 in the works and I think it may be the ultimate comprise between both worlds (TT-01 and TRF415). May be there is another equivalent you can find for R/C that will suit both your needs (whatever they may be).
