TT-01 Forum
#676
So it looks like you can mount the spur gear on and pinion independent from the chassis so the meshing can be looked at better. Or you you have to adjust the meshing when the mount is on the chassis?
I look at my beat up tub chassis... and I cry on the inside. But my next upgrade is my ESC--and I am waiting for someone to buy the sidewinder and sell it used
its bassically the same as a TB evo 4-5 only reversed. so you mount the spur and then mount your motor and align the meshing.
#679
Maybe some of you guys could help me out. Ive just fitted the front & rear stabilizer sets. on both front & rear i have used the yellow 'medium' bars. Now the rear bar is nice & tight, but the front bar is loose and it moves around alot. any help would be great.
#681
i wont be using them because look what i made
will be supplying better pictures soon when i pull the car appart again.
currently fitted is a 38t pinion and a 69t spur in HPI 48pitch gearing.
Final drive is now 4.72
#682
slyts6 - how did you make the spur gear adapter & can u give us a photo of it by itself? Cheers mate
#683
tt-01 stabilizer
question about stabilizer for tt-01,
is it helpful or just add beauty to a car?
and if its helpful in what way?
salamat
salamat
#684
alright, i fianlly built my first tt01 w/ a dx 2
and now i try to set it up....
i have 3 things that plug into the reciever,
my servo, some red one with 2 female plugs, and the esc.... where goes where?
also for some reason when i plug in all three of those i can only steer and not drive... and the esc is beeping and flashing...
also what colour shoul go with what colour on my motor.... i have green/yellow on the motor and orange/blue on the esc...
thanks
youngage
thanks
youngage
#685
basically i just turned it up on the lathe out of aluminium. it took about 7 hours to do...and i plan to make another one a bit better quality. this one isnt up to my standards but it works which is the main thing.
i made the holder to work in the same way as the actually TT01 gear works. pretty much being held in position by a pin but i had to shim the hold out slightly. i am unsure if the holder works on the TUB chassis though.
#686
[QUOTE=best of blue;4085990]question about stabilizer for tt-01,
QUOTE]
Stabilizer bars adjust side to side traction, by resisting body roll.
When an upwards force is applied to one suspension arm an upwards force is also applied to the other arm attached to the stabilizer. This makes the car ride flatter through corners. The weight is spread more evenly between both left and right wheels.
Without attempting to explain the physics, there is also an overall loss of traction|grip with the addition of a stabilizer. This has the effect of changing the balance of the car to the other end.
If your car loses traction at the rear when slowing and turning in (spins out turning under brakes), a stiffer stabilizer at the front (or softer at the rear) will make the car have more grip at the rear.
The basic rule, stiffer stabilizer at one end means more traction at the other.
Note that you are wasting your time if you don't stiffen the TT-01 it flexes so much that the stabilizers do stuff all.
I suggest a carbon fibre upper and the 3 Racing shock tower stiffeners - then you will be able to see the effects.
Kevin
QUOTE]
Kevin
#690
The plastic blocks supplied have 2 x 3mm grub screws which are adjusted to prevent the stabilizer from bouncing up and down. I would suggest drilling and tapping the aluminium blocks to take grub screws, if up and down is the problem.
If side to side is the problem then Tamiya 53827 stabilzer rod stoppers will do the job.
Cheers
Kevin
