Infinite Power 3800 >
Infinite Power 3800
Infinite Power 3800
Old 12-23-2005, 07:29 PM
  #16
UCHEATULOSE's Avatar
rc4less
UCHEATULOSE is offline
Old 12-23-2005, 07:55 PM
  #17
burbs's Avatar
http://www.lefthander-rc.com/catalog/index.php
both pole position and hefty cells in stock. you may have to call for 6 cells..
burbs is offline
Old 12-23-2005, 08:00 PM
  #18
SpeedTech's Avatar
Originally Posted by David Alberico
Where can I buy these batteries?
We stock a good selection of IP3800 by Pole Position broken down by voltage so you know exactly what you're getting
SpeedTech is offline
Old 12-27-2005, 02:55 PM
  #19
TTT
Bobby J is offline
Old 12-27-2005, 03:57 PM
  #20
fjm9898's Avatar
these arent ROAR legal though right?
fjm9898 is offline
Old 12-27-2005, 04:09 PM
  #21
Team EAM
Trader Rating: 79 (100%+)
They will be Jan 1st.
EA
EAMotorsports is offline
Old 12-27-2005, 04:20 PM
  #22
fjm9898's Avatar
so ex comm approved the new 44mm rule? or did IP meet the old 43mm
fjm9898 is offline
Old 12-27-2005, 04:34 PM
  #23
EddieO's Avatar
They kept it at 43mm.....but allowed a tolerance on the cells after charging/cycling, etc......up 1 mm....
I however, have never seen an uncycled IP cell under 43mm......GP and IB stuff are 43mm or smaller before cycled.....and once they are processed some get up to 43.5.....the IP stuff raw is like 43.5 or so.....they don't increase as much in size with cycling though......
Cycling=matching process.....
Later EddieO
EddieO is offline
Old 12-27-2005, 05:50 PM
  #24
mainracer's Avatar
Oh well, the most important has been done now they are roar legal like they should have been since the begining
mainracer is offline
Old 12-27-2005, 08:23 PM
  #25
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
have you had any personal experiance with the ip cells just curious what you thought of them so far thanks willy
HVFracingwilly is offline
Old 12-27-2005, 09:25 PM
  #26
ottoman's Avatar
... why should a cell that didn't meet the rules be ROAR legal "since the beginning"? Looks to me like they had to fudge the rules to make it legal
ottoman is offline
Old 12-27-2005, 09:28 PM
  #27
burbs's Avatar
Why do people care so much.. its been aproved and it is legal.. if you dont like the aproval of it dont buy them and bocott roar.. This thread is about the IP's// There is a million other threads on the subject of aprovals..
burbs is offline
Old 12-27-2005, 09:32 PM
  #28
burbs's Avatar
I also dont get this low runtime stuff.. all the ib;s i see are 460-480 for runtime at 30 amps.. I personally know one of the mathcers doing IP's he told me his cut off is 470 seconds.. under that he wont sell as race packs.. Ive also heard 500+ at 30 amps is being seen alot as well. so where is the low runtime??
burbs is offline
Old 12-27-2005, 10:03 PM
  #29
Team EAM
The lower runtime cells were the first version....The newest batch is really good from what I have heard....Ive seen cells of 500-510 at 30 amps....1.20+voltage and 1.6 IR's. Sounds pretty good to me but I havent matched any or run any.
EA
Old 12-27-2005, 10:28 PM
  #30
ottoman's Avatar
Originally Posted by burbs
Why do people care so much.. its been approved and it is legal.. if you don't like the aproval of it dint buy them and boycott roar.. This thread is about the Io's// There is a million other threads on the subject of aprovals..
Calm down burbs... you oval guys are SO touchy
I was merely commenting on the post that said the IP's should have been approved "since the beginning" well they didn't meet the length rule at that time so they shouldn't have been legal... but now that they .... ahhh... adjusted the rules a little so they are legal all is well with the world.
If or when EA tells me they are better than IB's I will have no problems buying IP's
ottoman is offline
