VBC Racing D08
#301
If you're interested in my barely used VBC D06, PM me...
#303
Are the 08 arms, hubs ect same as d07. And what's the difference between v2 and v3 c hubs. Are diffs the same? thanks in advance new the vbc brand cheers
#305
#307
#308
where can I get a d08 dynamic in north america
#309
I know that the D08 arms are better quality in many ways, however, I have a D07. I put some D08 arms on the car - the car was superb. Then a chap, trackside, had a D06 that was all over the place insofar as:
- roll bars bent;
- unequal droop left right
- unequal length shocks
Anyway - I helped sort the car out and put the same settings on his car as my own. Now he uses sticks - me a wheel - but I learnt on sticks.
I found his car to be very forgiving over the bumps, and was a bit better at generating grip. The d08 arms made the car sharper and more responsive.
All I am saying is, get some 08 arms, but the old arms can/do provide good options on set up -
BTW the track was tight, bumpy, low grip
- roll bars bent;
#311
First day out with the D08 was good! After each change the car gained a 10th per lap. I qualified 3rd and finished 2nd in the A main. The flex system works great and is very effective at changing the car. I will make some serious changes the next time I run it. The Hobbywing power was awesome as usual.
#312
Im using the standard shocks so Ive got no answer there. The solid pin mount seems to be fine so far, I would like to get some more inserts but their out of stock in Vancouver. Everyone was very impressed with the way the car behaved on track, I was only 5 seconds behind the fastest guy there in the class.
