Motor Problems Tamiya Brushless 10.5T TBLM-01S & ESC 01S TBLE-01 Sensored
I don't know what the problem is. I was running fine with my Brushless Sensored Motor and ESC were working flawlessly together. I am running on 2 Cell LiPo 5200 mah 35C and I have reset the ESC settings with no such luck to fix the problem.
If I'm going straight the motor has no problem. The second I start to turn I get cogging and if I turn at too high speed my motor will shut off for a few seconds. The motor is not even hot. The ESC says it's good 6.6-7.2v, maybe it is the LiPo causing the problems? The ESC overload, overheat, and undervoltage protection. It only happens as soon as I turn, the sensored motor just does not want to do both at the same time anymore. Please let me know what you think the problem might be. Thanks, -Mike |
One of two possibilities (there are others I dare say) that have happened to me:
Basically you need to swap out each element in the chain servo, receiver, esc to confirm where the problem lies but it is most likely a receiver issue. |
the savox can be used, you just need to plug in a glitch buster or similar style capacitor to an open spot in the rx
