Like Tree240Likes
Motiv RC
    Hide Wikipost
Old 02-13-2019, 04:00 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Motiv RC
Last edit by: Johnny Carey
NEW FOR 2018!
  • Defy G, Graphene LiPos
  • More Coming Soon...
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
John's Mobile Raceway / 180 Raceway
& More - Check your local hobby shop!
Defy Series Pro Li-Po batteries
MOV2015: GREY GRAPHENE PRO LIPO, 2S SHORTY
  • COMMON APPLICATION: Stock 10th Off Road, Mod 10th off road, F1
  • 95.5mm Length X 46.5mm width X 24.5mm height
  • 5000 MAH, 2S, 100C, 7.6V, 38WH.
  • 5mm through Bullet
  • Weight: 202g
  • COMMON APPLICATION: Stock TC, 4WD Shortcourse, Stock Dirt Oval
  • 137.5mm Length X 46.5mm width X 24.5mm height
  • 8400 MAH, 2S, 100C, 7.6V, 63.8WH.
  • Weight: 329G
MOV2018: GREY GRAPHENE LOW PRO LIPO
  • COMMON APPLICATION: Mod TC, Loose Track Mod Dirt Oval
  • 138.5mm Length X 46.5mm width X 22mm height
  • 6000MAH, 2S, 100C, 7.6V, 45.6WH
  • 5mm Through Bullet
  • Weight: 273g
  • Low CG
MOV2037: LOW PROFILE GREY GRAPHENE 2S LP Shorty
  • COMMON APPLICATION: Mod Offroad, F1
  • 92.7mm Length X 46.5mm width X 18.5mm height
  • 4100MAH, 2S, 90C, 7.6V, 30.4WH
  • Weight: 153g
  • Low CG
MOV2001: V6000 LIPO
  • COMMON APPLICATION: Stock & Mod 1/12 On-Road and Oval
  • 6000MAH, 1S, 90C+, 3.7V, 22.2WH
  • 4mm Bullet
  • Weight: 150g
MOVXXXX: GREY GRAPHENE PRO LIPO, 1S
  • COMMON APPLICATION: Mod 1/12 and Oval
  • 8200MAH, 1S, 100C, 3.8V, 31.2WH
  • 4mm Bullet
  • Weight: 150g
MC2 Series Brushless Motors
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Old 11-12-2018, 01:14 PM
  #946
There lots of parameters on a motor that can affect performance: inductance, resistance, stator steel quality, etc......For now, all we need is a photo of the MC3....
bertrandsv87 is offline
Old 11-12-2018, 01:24 PM
  #947
Dan Hamann's Avatar
Trader Rating: 27 (100%+)
Keep an eye out for a press release soon, I can say that I was impressed with the motor over this past weekend!
Dan Hamann is offline
Old 11-12-2018, 01:28 PM
  #948
Ok Dan....Can't wait !!!
Old 11-12-2018, 01:54 PM
  #949
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
RC*PHREAK is offline
Old 11-12-2018, 04:58 PM
  #950
Nice packaging ....Thanks.....
Old 11-12-2018, 06:47 PM
  #951
Jedd's Avatar
Trader Rating: 25 (100%+)
What is the ETA on the Approval of these motors from ROAR??
Jedd is offline
Old 11-12-2018, 10:45 PM
  #952
Now we just need a photo of the motor out of the plastic case?
I wonder if its it’s based off the European MCR motor?
Waztrain1234 is offline
Old 11-13-2018, 06:40 AM
  #953
Trader Rating: 52 (100%+)
NO
tonyd is offline
Old 11-14-2018, 09:35 AM
  #954
Trader Rating: 10 (92%+)
Starting gear suggestions for MC3?
Johnny Carey is offline
Old 11-14-2018, 12:41 PM
  #955
Trader Rating: 24 (100%+)
where do I send money for one?!
Scirocco is offline
Old 11-14-2018, 01:20 PM
  #956
i agree, I want one now.
Old 11-14-2018, 06:42 PM
  #957
boner's Avatar
http://teamgravityrc.com/MC3-17-5T-PRO-TUNED-SPEC-MOTOR-2-Pole-540-ROAR-COMPLIANT-p56979813
i got my at motiv web site
boner is offline
Old 11-14-2018, 11:02 PM
  #958
Only the 17.5t is available at the moment. I need a 13.5t.
Old 11-15-2018, 05:31 AM
  #959
Trader Rating: 23 (100%+)
13.5 is next to release im told 3 weeks
Jfowler is offline
Old 11-15-2018, 11:10 PM
  #960
RC*PHREAK's Avatar
no build sheet?
