Like Tree240Likes
Motiv RC
    Hide Wikipost
Old 02-13-2019, 04:00 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Motiv RC
Last edit by: Johnny Carey
NEW FOR 2018!
  • Defy G, Graphene LiPos
  • More Coming Soon...
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
John's Mobile Raceway / 180 Raceway
& More - Check your local hobby shop!
Defy Series Pro Li-Po batteries
MOV2015: GREY GRAPHENE PRO LIPO, 2S SHORTY
  • COMMON APPLICATION: Stock 10th Off Road, Mod 10th off road, F1
  • 95.5mm Length X 46.5mm width X 24.5mm height
  • 5000 MAH, 2S, 100C, 7.6V, 38WH.
  • 5mm through Bullet
  • Weight: 202g
  • COMMON APPLICATION: Stock TC, 4WD Shortcourse, Stock Dirt Oval
  • 137.5mm Length X 46.5mm width X 24.5mm height
  • 8400 MAH, 2S, 100C, 7.6V, 63.8WH.
  • Weight: 329G
MOV2018: GREY GRAPHENE LOW PRO LIPO
  • COMMON APPLICATION: Mod TC, Loose Track Mod Dirt Oval
  • 138.5mm Length X 46.5mm width X 22mm height
  • 6000MAH, 2S, 100C, 7.6V, 45.6WH
  • 5mm Through Bullet
  • Weight: 273g
  • Low CG
MOV2037: LOW PROFILE GREY GRAPHENE 2S LP Shorty
  • COMMON APPLICATION: Mod Offroad, F1
  • 92.7mm Length X 46.5mm width X 18.5mm height
  • 4100MAH, 2S, 90C, 7.6V, 30.4WH
  • Weight: 153g
  • Low CG
MOV2001: V6000 LIPO
  • COMMON APPLICATION: Stock & Mod 1/12 On-Road and Oval
  • 6000MAH, 1S, 90C+, 3.7V, 22.2WH
  • 4mm Bullet
  • Weight: 150g
MOVXXXX: GREY GRAPHENE PRO LIPO, 1S
  • COMMON APPLICATION: Mod 1/12 and Oval
  • 8200MAH, 1S, 100C, 3.8V, 31.2WH
  • 4mm Bullet
  • Weight: 150g
MC2 Series Brushless Motors
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Old 10-10-2017, 01:19 PM
  #706
Anyone tested a 13.5 motor on a motolyer as of yet interested in trying one to see if it's better than my Orion for 1c use
Quietman is offline
Old 10-11-2017, 03:32 PM
  #707
Suspended
I was hoping someone else with some knowledge of the Orion would chime in. My response will be a little biased of course, but I would bet the MC2 is a stronger motor. I don’t ever really recall hearing much buzz over Orion stuff in spec classes. I don’t have any motolyser numbers on a 13.5 MC2 to back up my thoughts.
R Dodge is offline
Old 10-11-2017, 03:48 PM
  #708
Suspended
New from Motiv, Defy Graphene series Lipos! Paul is releasing details on each new pack every day this week. So far we have the LCG 2s pack and the standard 2s pack:
MOV2018: 6000MAH, 2S, 100C, 7.6V, 45.6WH
Low CG
5mm Through Bullet
138.5mm Legnth X 46.5mm width X 22mm height
Weight: 273g
Best applications: Mod TC, Loose Track Mod Dirt oval
MOV1015: 8400 MAH, 2S, 100C, 7.6V, 63.8WH
5mm Through Bullet
Weight: 329G
Best applications: Stock TC, 4WD Shortcourse, Stock Dirt Oval,
Ivan Dickson, qcrc and silden like this.
R Dodge is offline
Old 10-17-2017, 01:13 PM
  #709
Default New Motors?
Are there new motors in the works?
JIJ5 is offline
Old 10-17-2017, 01:15 PM
  #710
Suspended
Yes, but no eta at this time.
R Dodge is offline
Old 10-17-2017, 09:02 PM
  #711
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
MC3?
Dan is offline
Old 10-17-2017, 09:30 PM
  #712
Trader Rating: 10 (92%+)
From what I understood, Paul was waiting for the dust to settle on the new rules.
Boostinswifty38 likes this.
Johnny Carey is offline
Old 10-19-2017, 08:18 PM
  #713
Trying to help my buddy out who runs a Motiv motor. How do you guys set ampdraw back to the way he received it? The end bell and stuff came off and needs to get it back
Racecarguy is offline
Old 10-20-2017, 01:44 AM
  #714
the MCR have the same performance and gearing of MC2 ?
Lizard66 is offline
Old 10-20-2017, 02:49 AM
  #715
Suspended
Mine are usually around 3.0-3.2
Don't know, I don't think anyone in the states has tested the MCR because it is not ROAR approved. I doubt it is identical but I will ask Paul if you'd like. What class are you looking to run it in?
R Dodge is offline
Old 10-20-2017, 02:53 AM
  #716
yes, if you can ask Paul, i want run 13.5 blinky class , and i want more information about MCR , because in Motiv site not are information about the MCR
Lizard66 is offline
Old 10-20-2017, 02:55 AM
  #717
Suspended
Okay - is this TC? 1/12? 4WD Buggy?
Thanks!
R Dodge is offline
Old 10-20-2017, 02:56 AM
  #718
touring class 1/10 outdoor medium/long track size
Lizard66 is offline
Old 10-20-2017, 02:59 AM
  #719
Suspended
Got it. Will let you know what he says.
R Dodge is offline
Old 10-20-2017, 03:53 AM
  #720
Trader Rating: 19 (100%+)
The shaft is too long for my Awesomatix A800XA. It's hitting the battery unless I shim the motor out at least 1.5mm.
Can I trim the shaft without any ill effects on the motor?
Basically is that going to throw the balance of the rotor off?
iTz Nicholas72 is offline
