Motor temp
Motor temp
Hey I have a temp probe that I can stick in the motor and that's what I have been doing to take temps. Should I stick the probe on the outside can or in the brushless motor where the windings are?
What's the target for temp?
Depends on the motor.
But general rule of thumb is don't exceed 160F / 70C on the track
Many motors can take more, but heat will be the death of any brushless motor eventually if run too high.
Ok cool because when I check the windings my temp gauge saw 80c at most but on the can it has not gone up to 70c yet.
During our HOT summers I've temp checked my 21.5 GT motor after coming off from a 4 minute race and have seen 190F (before installing a fan), motor is still working fine with no noticeable drop in performance....not that there isn't any...just can't tell. This is with timing max'd out, if not max'd out (like everyone else) you get passed a lot.
Bought the Muchmore Ultra High RPM fan and high temps are closer to 170F-180F.
We race at night between May and October, otherwise we're racing when it's 100 plus degrees with the sun beating down on you. It's still over 100 at night but at least we're not under the sun too.
Well it was 80F outside when I was testing the motor temp. In mid Sumer it gets up to 115F so I'll be watching the motor temps when it gets hot out. I have a speed passion 7.5 turn 5700kv motor on a 4 cell lipo to go fast.
Lasvegas is almost the same thing and that's where I live.
