How to Get Traction Out of Smooth Concrete Surface. >
Old 04-04-2015, 08:53 AM
AZDemille's Avatar
Default How to Get Traction Out of Smooth Concrete Surface.
The new on road track at SRS is a lightly etched concrete surface.It is mostly covered and contained but the ceiling is mesh so there will be normal dust coming in. We are looking for proven methods to get the traction up. They first tried blowing off the dust and applying VHT. But the VHT tended to ball up on tires. And of coarse VHT is expensive. They are now trying to build up a thick base layer of soda. The first application did not provide enough traction. The plan is to try and build up this layer this week then blow and apply a fresh top cote on race night. Does anyone have suggestions to get the grip up on this type of surface?
AZDemille is offline
Old 04-04-2015, 10:15 AM
CristianTabush's Avatar
There used to be a track in Oklahoma that was concrete and high bite. I believe they used to spray WD-40 on the track.
CristianTabush is offline
Old 04-04-2015, 10:54 AM
We used soda on a concrete track we had for a short time...problem was the soda stuck better to the tires than it did to the concrete and glazed over the tires. We found that using sun tan lotion on the tires reduced the amount of sugar that stuck to the tires. It helped but wasn't an ideal solution.
InspGadgt is offline
Old 04-04-2015, 11:00 AM
Johnny Wishbone's Avatar
I keep thinking transmission fluid, but can't remember if it was on concrete, perhaps someone else knows more.
Johnny Wishbone is offline
Old 04-04-2015, 11:06 AM
SWTour's Avatar
There was an indoor track years ago that raced on the concrete floor...but had it coated w/ the same stuff you'd put on a concrete tennis court (w/traction) - I'm sure it was some type of epoxy coating ... and I believe they said that it had crushed walnut shells that provided the grip.
SWTour is offline
Old 04-04-2015, 12:23 PM
How would asphalt sealers do? I don't know......came to mind and was wondering.
what brakes is offline
Old 04-04-2015, 12:47 PM
Geezatec's Avatar
Agree With Insp, Soda. Pepsi cuz of Fructose content. Most on-road tracks use sugar water in gardening sprayer, cheaper than soda, spots where its needed. Track only prepare during races. the wors
Asphalt sealer the makes it slicker for 72hrs. Still will need soda or sugar water.
Epoxy the worst, it make in slicker, You mite as well as using it as a Drifting track.
Last option, tire dressing.
Geezatec is offline
Old 04-04-2015, 02:25 PM
tmail55's Avatar
Trader Rating: 61 (100%+)
One of the tracks I race at uses this to seal the asphalt and concrete on road / oval track, sealed the track Sept 2014. Race every Sat, they only blow the track before practice, haven't needed a reseal.
http://www.t3t4webservice.com/mann.html
Video from Jan 2015 track still looks good!!
https://www.youtube.com/watch?v=LXKkgF1vfQU
tmail55 is offline
Old 04-05-2015, 02:57 AM
evochick's Avatar
I am not sure what the US equivalent is, but in Aus we use Boral coat on our concrete tracks
http://www.boral.com.au/productcatal...px?product=476
evochick is offline
Old 04-07-2015, 04:47 PM
AZDemille's Avatar
Was the track you showed concrete? Looks like the surface is pretty good.
Old 04-07-2015, 06:23 PM
Any kind of sealer is just going to make it slicker. The only way to make the actual concrete rougher is to etch it more with muriatic acid. No idea if that would bring traction up or down though.
Their are concrete nascar tracks. Maybe you could get a hold of someone at one of those tracks and ask if they have any ideas.
2uzferunner03 is offline
Old 04-07-2015, 08:49 PM
OttoKrosse's Avatar
This may not be what you want to hear....but here goes. Traction is NOT the only issue that needs attention, as I've stated in a previous posting.
The track is too short for 1/10 touring cars and GT cars, you can run Tamiya minis on it and maybe VTA. I was very surprised to see how short the straight is and how poor the visibility is from the north end of the drivers stand while negotiating the north end portion of the track......and I know I'm not the only one that thinks that.
Solution to the issues at hand:
Go out front and paint a nice big layout in the parking lot where viability is unhampered by 18-24 inch wide support beams covered with decorative bricks. Run the straights in a north / south direction to take advantage of the parking lot. Traction can be improved greatly using a blower and grape soda. Then you'll have a track that will draw in every TC driver within 50 miles.
Until I see a bigger layout it's not worth my time to drive the 40+ miles from east Mesa, make numerous changes to 2 cars to accommodate the small track only to have to change everything back for the Gilbert Hobby Town races on Saturday.
I do like the basic layout of the track but to me it needs to be a lot bigger, and a lot more accommodating for spectators. As it is I don't see much room for people to watch the races. IMHO
...and just to be fair, I think Hobby Town Gilbert could stretch their layout a bit for it to be a faster track, unfortunately some of the parking lot barriers are preventing us from enlarging the racing surface.....but at least we have traction and an unobstructed view of the entire track.
OttoKrosse is offline
Old 04-07-2015, 09:16 PM
RotorTruck's Avatar
The tennis court I practice on sometimes is concrete and has a thick ruBberized surface sprayed on it with good traction. No clue about walnut shells.
RotorTruck is offline
Old 04-08-2015, 03:04 AM
tmail55's Avatar
It's about half concrete, half blacktop.
Tires > nitro guy run foam, ele run rubber.
tmail55 is offline
Old 04-08-2015, 03:32 PM
AZDemille's Avatar
Interesting. I asked they manufacturer of the product you recommended and they said it was not for use on concrete. I was just curious if your track was concrete and if you had any adhesion or peeling issues.
