Tekin vs. Novak
If size is any consideration even with the external capacitor the GTX is smaller than a Tekin. As far as performance goes, the GTX just won the Reedy race (most recent) and prior to it has won More races than any other speedo out.
well i drive a tempo and i find the gas mileage is comparable to that of a jetta, oh wait, you asked about the G-10, GT-7, or GTX
Cuffs-I used to love ya..but I have to kill you...(GnR).. the picture shows that with the capacitor on it's side it is the same size as the Tekin...but you can as I do, mount the cap on top. It's all how you look it a it...You run for Tekin and I run for Novak, so I venture to guess our opinions are slightly biased!
Oh and heavier is better...it means it was built using more go fast juice!
Butter
Butter
Simple answer.......Hara Twister 2.1 !
Adrian-3 words......Factory Hot Mod
LMFAO!!!!!!!!!!!!!!!
I ran both Tekin G10 pro and GT-7.
No way to compare. Tekin g10-pro is much more better than GT-7 in term of everything. But GtX, not known.
I will have to agree with Cuffs on this one. I have ran the GTX and the G-10+. I definitly like the Tekin much better. This is why(more adjustments, easier setup, and easier to adjust and it also has a self check system)And as far as size is concerned. Cuffs runs corrally and I run Xray. Both of them are a little short on room for electronics. We both have no problem fitting it in the car. But then again my opinion might be a little bias. LOL
Customer service for both companys are probably a tie. They both support there products very well.
KT
KT
cuff... you better have that G11 you have check up...
remember you are running 18 fet instead of the 20 tekin gave you...
image if you can get those fet all clean up... and with the stupid arse fan
i gave you... loosing an extra of 0.00001 second is not a dream!
~ming
~ming
