Tamiya TRF419
#1291
Not interested in your let's play possum games.
#1292
Hi,
Where can i read/learn more about impact of front arm settings?
Let's say difference between C-C block setting vs C-B setting with shim to have same wheelbase. Toe both case 1 degree.
I would like to understand differences (advantage, disadvanage), if any.
Thanks,
Marton
Thanks,
Marton
C/B gives a bit of front arm sweep. This helps to stabilise the camber change mid-corner, and gives more mid to exit steering. A bit like more castor, but doesn't reduce the initial steering. For tracks with sweeping turns I find it better. It also narrows the front a little, giving a little more front bite.
C/C blocks are good for stabilising the front (as a bit wider), and if you want more initial steering.
You do need to bare in mind the wheelbase whilst using sweep. 0.5° of sweep will shorten the wheelbase by about 0.5mm.
As for the front toe, it should be 1° toe-out... I didn't pay attention too the diagram properly Arm sweep doesn't affect the overall toe setting (unlike on the rear) due to the steering links being adjustable.
Also, finally managed to get last tuesdays SMA setup uploaded (wordpress is being temperamental at the moment)
Ed
Ed
#1293
#1294
Thx, i have read it already! Anything more advise/experience in my example (C-C vs C-B same wheelbase with wheel spacer)?
#1295
Hi,
Thanks,
Marton
Thanks,
Marton
regarding the 419. I'm really enjoying racing mine. The corner speed is still catching me out. The main area I need to address is that the car is rolling quite a lot when I hit some sharp S curves (I race on a very technical small track at my local club) I think I might actually try a little front sweep (never really played with it) and move out the shocks one hole on the front.
I also have 0.5 under the rear blocks (not at the front) It was great like this on my 418 but I wonder if the roll centre's might be a little too different from front to rear to make the car feel unsettled when transitioning from left to right on the brakes...
Just thinking aloud, I'm sure when I read this back I will understand what area to attack first.
#1296
Thx, i have hudy set up book which i use a lot . Will this xxx book give more info about settings? I am thinking to buy it. Need to learn, car works perfectly despite i miss order of settings and how to read the car to become quicker. Unfortunately i have limited knowledge. What to change first....
Check out XXX main book by Martin Crisp. It's excellent, also the Xray manuals have a lot of info on basic set-up and they are free to download.
#1297
#1298
The XXX book isn't very helpful. It mainly goes on about weight shifting (which is correct as a fundamental principle) but doesn't go into as much detail as the Hudy books. The Hudy books on the other hand don't explain why you need to do this that or the other, so a combination of the two sources is best. Either way, as a principle remember the weight shift is the core, and take it from there. All you're doing with tuning is make sure you shift the right amount where it's needed under every possible circumstance.
PS. I think I downloaded my copy of the XXX book from the interwebs many moons ago. Might still float about if you're lucky.
#1299
This is the latest stuff from Martin Crisp.
http://www.learnsetup.com
XXXMain is 10yrs old now after all....
#1300
Hi,
Thanks,
Marton
Thanks,
Marton
http://www.rctech.net/forum/electric...s-effects.html
Generally, straight arm will give more initial steering, but loose out a bit mid-exit. Sweep will loose a little initial, but gain in mid-exit.
Bare in mind sweep can also be added by making the front wider (say D/C) or narrower (C/B) over the kit C/C... narrower tends to make the car a little more aggresive, wider more stable. So narrower with C/B tends to help compensate for the loss of initial vs the straight arm.
HiH
Ed
#1301
Oops. You are right. Described it round the wrong way. I was 6deg blocks with 0,5mm anti-dive (under FR blocks) on my 418. One kinda cancels the other out partially? It's was docile and stable, yes.
Nb: I thought I had my terms right, but then looked at the hudy book and second guessed myself. Which (pg 46) talks about "anti" dive in the positive sense only (front kicked up)
And your correct that B's on the rear will give 2°... but... I'd worry it would make the rear end too wide, and moving the pin out also affects the shock position (as the lower position moves further out from the centreline relative to the top position).
I would look at going A/E for the rear blocks if you can find some Sep A's, but I haven't seen any available yet. That would give same width as kit X/F, but with 2° of angle instead
The other alternative is X/D.. but that has the reverse effect to B/F (2° but narrower). Although, it's worth noting that X/D would be the same width as the popular XA/E combination.
Might be worth trying B/F and X/D out though, see which you prefer
#1302
^ yup, no A's and no D's available (as of yet!)
Odd they skipped A in the mix of XB, XA, X, ?, B, C!
#1303
Correct me if I am wrong, but I was under the impression that The 54172 split blocks were either an A or XA depending on how it was installed on the car.
https://www.tamiyausa.com/items/radi...s-mounts-54172
#1304
Split blocks for 419
Just my 2$
#1305
Hi All,
Thanks for comments help.
See below link my set up as well as the track. Car was very good, I missed a little bit of being "quicker". Best time was around 13mp/lap, I could make 13.2. I know thisgap can be also in my hand :-) but if I can make it from car would be great :-)! Motor screws in bottom are 1-1 center, no other screws missed or whatever, comes with KIT. C hub is shimmed by 0.2mm.
Set up:
https://plus.google.com/photos/11620...CPTwmd-RrpOBWw
What I wanted to try but didnt have time either to have harder stabilizer set both front and rear and/or lower roll center.
Thanks for your feedback.
Marton
Set up:
Marton
