Like Tree256Likes
Tamiya TRF419
Old 12-13-2018 | 07:24 PM
  #4186
ShtLuck's Avatar
I will have to look for them.
ShtLuck is offline
Old 12-14-2018 | 12:30 AM
  #4187
Seidel rc doesn’t ship outside Germany
Gerd is offline
Old 12-14-2018 | 09:53 AM
  #4188
Originally Posted by ShtLuck
so i just ordered a 419x i will probably go xr at some point. I am running in USGT and coming from a TB EVO 7 that i struggled with the crazy amount of grip it made on CRC black carpet. Anything i need to do for black carpet or any band aids i need to know about during the build up? also what is a good starting point for the car on black carpet?
I would start with stock setup which is good starting point. I race with some minor changes:
1. Less front toe out (around 1.5)
2. Springs (I use SMJ - 2.8 or 3.0 linear rear, 2.7-3 progressive front
3. One step harder front antirollbar
4. Soft (ball) central stiffener
5. Top Deck from WS
If you use alu deck I would recommend to use thinner top deck (Vigor 1.6)
Diff oil 6k up. Lately I use 8k some use 10k
Dampers oil 450-500
Important:
1. Mill/sand topdeck near spur gear as the clearance is too small. While driving it will spur rubs against topdeck (I had this in 419X, WS and XR as well)
2. Use third bearing inside spur gear (pulleys). You have to buy this separately. It will save you pain with sloppy spur and shaft. In the end pulleys would have to be replaced as they wobble. It cannot be shimmed as the shims press against bearings making them too tight.
Those are IMHO two obvious flaws in this model.
airbiscuit likes this.
Macio4ever is offline
Old 12-14-2018 | 10:36 AM
  #4189
5. Top Deck from WS
Dampers oil 450-500
Important:
Can you share a pic of what you do with the Spur? Sounds interesting. I shim to stop the spur wobble, but your idea sounds better.
Thanks,
Jose
ittjv is offline
Old 12-17-2018 | 01:47 AM
  #4190
I used third bearing (3 or 4mm wide) inside one of the pulleys - red arrow shows where you should put your bearing. With three bearings shaft and pulleys have close to none play. When assembled I have just very, very tiny play (I think < 0,1mm) and spur spin freely for a couple of seconds. This tiny play is needed as spur and pinion will nicely mesh.
Bearings are standard size but different ones for X/XWS and XR (XR has thicker shaft).
TRF419X Pulley and additional bearing
Qatmix and airbiscuit like this.
Old 12-17-2018 | 01:25 PM
  #4191
trf415msx's Avatar
Anyone know anything new for tamiya this time of the year.........new trf
trf415msx is offline
Old 12-17-2018 | 03:06 PM
  #4192
The TA07MS has just started to hit stores (That is a new TRF, a single belt 419XR). Also the 419XR has recently been released globally as a full kit. It will be a while before a new 419 but there will be one at some point I am sure
Qatmix is offline
Old 12-17-2018 | 06:07 PM
  #4193
97Clemow's Avatar
https://www.tamiya.com/english/news/news1901/news0.htm
tamiya japan page new releases
97Clemow is offline
Old 12-18-2018 | 06:01 AM
  #4194
What is the effect of using F1 FR0.5/F0.5 FR1
tommy1030 is offline
Old 12-20-2018 | 01:13 PM
  #4195
Airwave's Avatar
sorry but there won't be any new trf cars...
But probably great MS cars...
Airwave is offline
Old 12-20-2018 | 02:25 PM
  #4196
Raman's Avatar
And you have this information based on what?
There will infact be more TRF cars and MS cars.. this is from sources in Tamiya.. so please don’t spread unverified rumours
Raman is online now
Old 12-22-2018 | 03:56 AM
  #4197
Which front uprights comes with the original 419x kit?
Its it the 418 C Carbon #54568?
airbiscuit is offline
Old 12-22-2018 | 08:58 AM
  #4198
Yes this is it.
Old 12-24-2018 | 12:33 PM
  #4199
trf415msx's Avatar
Originally Posted by Tom1977
For carpet i recommend the 419X-WS aluminium lower deck and the 1.7mm X-WS upper deck. But both hard to get...
looking for TRF419X aluminum chassis anyone have it for sale pleas pm me
thank you
Old 12-27-2018 | 02:33 AM
  #4200
Default Looking for. 419x aluminum chassis
I’m also looking for a 419x aluminum chassis. Please pm me if you have one for sale
Juan Aveytia is offline
