Like Tree256Likes
Tamiya TRF419
Old 06-22-2018 | 08:48 PM
  #3871
What is the size of the c clip for the spur/center pulley?
I am on the 419xr kit.
airbiscuit is offline
Old 06-23-2018 | 12:16 AM
  #3872
Tom1977's Avatar
Part MA8
E-Clip 4mm
Tamiya #50380 (set with other e-clips)
or
Tamiya #9465514
airbiscuit likes this.
Tom1977 is offline
Old 06-23-2018 | 07:32 AM
  #3873
Originally Posted by Tom1977
Part MA8
E-Clip 4mm
or
Tamiya #9465514
Since its 4mm so I can just use any other brand. Thanks.
Old 06-23-2018 | 10:19 AM
  #3874
nubs's Avatar
Just make sure it doesn't block anything and seats correctly around the inner groove.
nubs is offline
Old 06-24-2018 | 04:40 PM
  #3875
The rear diff. uses the aluminum cup/outdrive. Is there a replacement for it so I can use steel ones?
Old 06-24-2018 | 08:46 PM
  #3876
nubs's Avatar
Why would you want to?
nubs is offline
Old 06-24-2018 | 09:07 PM
  #3877
Just wanting to try something out.
Old 06-24-2018 | 09:31 PM
  #3878
Phat-Boy's Avatar
Which car will handle better in small black carpet 419x w or 419xr? 419xr does not have aluminum chassis option.
Phat-Boy is offline
Old 06-25-2018 | 12:04 AM
  #3879
The TA07 has steel ones that will fit.
Qatmix is offline
Old 06-25-2018 | 04:17 AM
  #3880
Thanks. I'll try to look into that.
Old 06-25-2018 | 06:22 AM
  #3881
nubs's Avatar
True but the XR has center stiffener options that can make the chassis incredibly stiff.
nubs is offline
Old 06-25-2018 | 07:42 AM
  #3882
Tom1977's Avatar
You can use the aluminium lower deck too with -XR. You only need the old -X motor mount, the old servo mount, the XWS upper/lower deck, the center post and some small parts:
- Tamiya #3450749 (Motor mount TRF419X) which you already have, when you come from a -X and using a -XR conversion kit.
- Tamiya #3450640 (Motor mount axle 4mm TRF419X) which you already have, when you come from -X and using a -XR conversion kit.
- Tamiya #9804778 (2pcs. E-Clip 3.2mm) which you already have, when you come from a -X and using a -XR conversion kit.
- Tamiya #9804777 (2pcs. M2.6 screws for axle) which you already have, when you come from a -X and using a -XR conversion kit.
- Tamiya #3450754 (Servo mount TRF419X) which you already have, when you come from a -X and using a -XR conversion kit.
- Tamiya #3450823 (Aluminium lower deck TRF419X WS)
- Tamiya #3404068 (Carbon upper deck 1.75mm TRF419X WS)
- Tamiya #3450751 (Center post TRF419X) which you already have, when you come from a -X and using a XR conversion kit.
There are so many variations possible now with all TRF419 versions...
Tom1977 is offline
Old 06-25-2018 | 09:46 AM
  #3883
The alloy chassis from the WS just fits on the XR. You do not have all of the lower attachments holes along the centre but they are for the centre link anyway
Qatmix is offline
Old 06-25-2018 | 01:11 PM
  #3884
My experience is that XR is just a hair better overall. It is not huge difference - just more precise and predictable, I would say - refined. I use XR with ball cups stiffener (carpet and asphalt) but with WS top deck on asphalt.
Macio4ever is offline
Old 06-25-2018 | 04:39 PM
  #3885
The TA07 arms front & back is supposed to be the softest compared to 419 & 418?
That is what I read somewhere, I think. Anyone tried the TA07 arms on their 419? Does it fits 100%? How is the outcome?
