Like Tree256Likes
Tamiya TRF419
Old 03-09-2017 | 06:26 PM
  #3286
Originally Posted by nubs
1) Correct, the key item is the silicone o rings
2) Yes, apply green slime or some other grease that is compatible with silicone. You would apply this to the o ring, the inside of the rod guide, and the rod where the threading is. Putting a generous amount of green slime on the threads will help prevent damaging the o rings.
3) I don't know about the red/orange o rings, I have never used them.
edit:
Can anyone explaint o me the love for the red o rings? Why not use these:
https://www.tamiyausa.com/items/radi...-o-rings-42137
Aren't these blue O rings the TRF419X's stock O rings that create the oil leak issue in my dampers?
Kakaru is offline
Old 03-09-2017 | 07:22 PM
  #3287
nubs's Avatar
No, the ones that cause the oil leak are these:
https://www.tamiyausa.com/product/it...oduct-id=42214
nubs is offline
Old 03-09-2017 | 08:18 PM
  #3288
edit:
Hi,
So the tamiya TRF blue competition O-Rings (P3 size) are better than the clear O rings in terms of preventing oil leak and durability? From the description in RC Mart of this product, it requires additional shims (Tamiya #53586) for clearance. Is it really necessary to get the shims if I were to use this blue competition O rings instead of the clear O rings?
Thanks.
Kakaru is offline
Old 03-09-2017 | 09:30 PM
  #3289
Hi,
Thanks.
Thanks guys. I will give the clear o rings a try.
Kakaru is offline
Old 03-09-2017 | 11:49 PM
  #3290
Will the front belt from any other tc fit my 419?
Just seen mine has torn and I need one for tonight but nobody else near me runs a 419.
Will yokomo bd7 belt fit?
hipwell is offline
Old 03-10-2017 | 12:54 AM
  #3291
I have just noticed that the bd7 belt is 172 teeth. Tamiya is 171. Is this a big enough difference to mess up front and rear wheel speeds?
hipwell is offline
Old 03-10-2017 | 03:57 PM
  #3292
Default 419x spring rates
I just got a 419x and I was wondering what the different color spring rates are?I have the chrome set pink and blue , and the TRF black springs that are GRN,RED and BLK .
dan22 is offline
Old 03-10-2017 | 11:11 PM
  #3293
JoJo1241's Avatar
It does not mess up your your front and rear speed.
It stays the same.
That only changes when you alter the number of teeth front or rear from your pulleys.
You just need to see if the bd7 belt can be set tight enough.
JoJo1241 is offline
Old 03-11-2017 | 08:31 AM
  #3294
Got a belt designed for bd7/t4 and it fit perfectly. Thanks.
hipwell is offline
Old 03-12-2017 | 09:18 AM
  #3295
nubs's Avatar
You were in fact correct. I thought it was the xrings because I've had leaking issues with the xrings.
nubs is offline
Old 03-13-2017 | 01:50 PM
  #3296
theproffesor's Avatar
If you are looking for some spares for you're 419 or 419x (at least the axles and couplings for the 419x) I've got some DCJ's up for sale.
http://www.rctech.net/forum/r-c-item...l#post14868441
theproffesor is offline
Old 03-15-2017 | 05:14 AM
  #3297
Tom1977's Avatar
I use X-rings with 4mm shims. No leaking and super smooth.
Tom1977 is offline
Old 03-15-2017 | 08:27 AM
  #3298
It probably had something to do with the application of green slime which I didn't apply in the first place.
Nonetheless thanks everyone!
Kakaru is offline
Old 03-15-2017 | 08:34 AM
  #3299
Default TRF419X damper's overall length
Hi guys
May I know what is the overall length that you built for these TRF419X's Super Short Big Bore ("SSBB") shocks, when piston is fully pulled out, with the caps and everything on, except the spring?
I didn't managed to find a good answer on the Internet and it isn't indicate in the assemble manual too.
Thank you.
Kakaru is offline
Old 03-15-2017 | 08:51 AM
  #3300
Tom1977's Avatar
Hi guys
Thank you.
I built mine with 54,0mm overall length.
Tom1977 is offline
