TC3 Torque steer?
TC3 Torque steer?
I have a TC3 that I just started really trying to race with and I've noticed that the car tracks straight unless I get on the throttle. It seems to severe torque steer to the left. Has anyone else noticed this? Is there a way to correct it? I'm still able to race with it but it does make it a little difficult at the start and coming out of corners.
BTW the servo I'm using is temporary and is the Traxxas 2075 (125oz) servo.
how many turns motor ??
Please try to set 0 degree toe-in.
Make sure the car doesnt have different droop amounts on each wishbone, same goes for camber etc.
Once the car is all straight n true then start to look at your diffs.
Are they to loose if ball diff or not thick enough oil if gear diff
Also not sure how strong 125oz is in kgs but a weak servo wont help either
