Old 12-21-2013, 01:52 PM   #1
Default TC3 Torque steer?
I have a TC3 that I just started really trying to race with and I've noticed that the car tracks straight unless I get on the throttle. It seems to severe torque steer to the left. Has anyone else noticed this? Is there a way to correct it? I'm still able to race with it but it does make it a little difficult at the start and coming out of corners.
BTW the servo I'm using is temporary and is the Traxxas 2075 (125oz) servo.
LST2 E BL, Losi 8ight RX8/2150kv,
TC3 BL, Losi XXXSCT BL
jrowles91 is offline   Reply With Quote
Old 12-21-2013, 06:46 PM   #2
moparSRT's Avatar
diff or spool up front ??
how many turns motor ??
moparSRT is offline   Reply With Quote
Old 12-21-2013, 07:01 PM   #3
Diff up front and rear. Different motors have been tried but now I'm running Tekin 17.5t.
Old 12-21-2013, 09:01 PM   #4
Please try to set 0 degree toe-in.
tc3driverhk is offline   Reply With Quote
Old 12-21-2013, 10:28 PM   #5
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Could be loose diff,chassis tweak
OVA is offline   Reply With Quote
Old 12-21-2013, 10:52 PM   #6
The TC3 was known to have torque steer issues.
KyoshoSC is offline   Reply With Quote
Old 12-21-2013, 11:05 PM   #7
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Only with brushed motors. Brushless turn way less rpms but make torque, which explains how we got to gear them in the 3.8 or so for 17.5 to run.
Also, the droop needs to be exactly the same l/r.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 12-22-2013, 03:15 AM   #8
Make sure the car doesnt have different droop amounts on each wishbone, same goes for camber etc.
Once the car is all straight n true then start to look at your diffs.
Are they to loose if ball diff or not thick enough oil if gear diff
Also not sure how strong 125oz is in kgs but a weak servo wont help either
PurcyP is offline   Reply With Quote
Old 12-22-2013, 02:17 PM   #9
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
We used to set rear droop differently right and left to correct this issue. you will have to play with it.
like 1m droop difference.
Jaz406 is offline   Reply With Quote
Old 12-22-2013, 02:25 PM   #10
snoopyrc's Avatar
Anything above 90 oz of torque should be fine for a touring car. As long as it's fast.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 12-22-2013, 03:06 PM   #11
Awesome, thank you guys for the assistance. I will check these my next time out!
