Handling help
Handling help
Ok, I have my TC3 set up with 50wt shock oil all around, red front springs, blue rear, and no sway bars. at first I had no steering, I removed the front sway bar and corrected that, but now if I turn, it tends to slide out. I moved the battery to the rear position as well. What can I do to get my rear end to stick better and keep my steering good? What about moving the top shock position out? lighter shock fluid? Any help is appreciated.
Re: Handling help
What rear toe are you using? Shock mount positions? tires? camber? All these can make a major difference with only slight changes. I used to run my TC3 with 3 degrees rear toe -1.0 degrees camber and Yoke 5g tires. I always had lots of steering and the rear end was planted!
Interceptor,
Have you tried different battery configurations, 3x3 or 4x2, moving the foam to the inside. I currently build all my packs in the saddle (3x3) configuration and run the foam in the middle. With my TC3 moving the batteries makes a big difference with how the car handles.
I would also run lighter oil in the rear, 40 or 35.
Good luck
Good luck
I don't know much about TC3's, but I'd try either a softer rear tire, or softer rear spring, for starters. If the car seems like it's biting too hard in the front (kind of trying to traction roll), go to a harder front tire, stiffer front spring, or add a lighter front sway bar than what was on the car before.
