Team Associated TC6.2 Touring Car
#2327
Because it is blue ?
#2331
Set Up Question - Need Advice
Hello all, new TC6.2 driver here with a set up question. Got to drive my car at my new local track and I'm finding that at about mid corner on a high speed sweeper to the left the car picks up the inside front tire until I start to sraighten the car out for the straight away. The car also did this in a sharper left hand turn.
I'm running purples in the rear with double pinks in the front. Our new track does not allow traction compound or sauce of any kind. I have the car set up exactly as how the instructions show assembly of the car. I seem to be getting plenty of traction even without using any compound or sauce.
I was contemplating removing the front sway bar entirely. Years ago I had a HPI touring car do this and that's how I got the car to keep the front inside tire on the ground and not act like a flat tracking late model.
Would this be the best way to remedy this situation or should I do something else and leave the sway bar in place?
Thanks!
Thanks!
#2332
Thanks!
Thanks!
#2334
Also, without trying the shock and sway bar changes first try removing all shims under the rear ball stud bulkhead side. This make it roll less but if it still rolls that much you will have to resort to the first changes I advised. Another thing I am going to test that is aimed to fix this over roll is more shims under the rear arm holders, give me a couple weeks to test that thoroughly.
#2335
And I quote from a pm from Ed (he runs on medium grip asphalt andand no sauce)
#2336
Any info on a new car yet?? Looking to pick up a tc for the winter months here. If something new is coming I'll just wait till the new version comes out.
#2337
Thank you very much for the help!
#2338
kyosho, Xray, team durango, yokomo, team C... all have released there new touringcars.
lower, faster, lighter inovation, stronger, better finishing quality. It will not be easy to make the AE TC as competitive as these companies, that will offer the best of the best. I'm curieus to the new TC7, ( parts of the TC5, TC4?) looks little bit silly. but it's time to replace my TC6.2. For the moment i will go for the new xray T4 or the Detc410V2. How surieus will AE go with there future TC?
gtz
gtz
#2339
gtz
gtz
#2340
After so much talks & speculations, are we going to have a new kit or not??
When??
When??
