Xray X1 - Formula One Car
#723
#726
Outer. I honestly have never tried inner. I only go to gluing side walls as a last resort to setup issues.
My X1 was dialed in yesterday. The usual fast guy in F1 with his X1 was having traction rolling issues. Traction was high. I have no clue what difference in setup between us was, but my car car stayed flatter and did no over work the tires. No tire chirping like many others. It felt more like my 1/12 scale then a rubber tired car.
#727
I was having issues running on slightly loose track conditions when I was breaking. The car was shoot off to the left when ever I hit the brakes. What can I check to see what's causing this problem?
#728
Car can be "tweaked" but more then likely you have too much brake{push brake} Try turning the EPA down on the radio until the car still stops but doesnt want to spin out. If you are talking about at Norcal,more then likely it was the track conditions that caused your issues.
#729
#732
If the track is super bumpy, the grease/lube will help but will probably have to be reapplied more frequently because as the knuckle or steering knuckle goes up-and-down it shears away the lube from the actual kingpin. So yesit should help and is a tuning aid but you will need to maintenance it more frequently.
#733
For that you have the System Set-up del coche Pan 1/10 y 1/12 and you want use it, you indicated what you have to do. XRAY 930508 - BALL-BEARING 5x8x2.5 (2), metric 4 washer (1) and 109360 - HUDY ALU NUT FOR 1/10 TOURING SET-UP SYSTEM (1) all for each axis.
#734
Hmm, I see a floating servo mount in this cars future.
