Xray X1 - Formula One Car
#316
#317
I think he was talking about the front wing.
>Serpent Front wing F110 (big+small) (#411294)
#318
Included in the kit is a similar one, only Xray brand of course.
It looks a bit odd, but are two wings from one mold, 1 high and 1 low down-force
#321
Looking at pics I can't see why they wouldn't.
Skiddins
#322
do springs from the tamiya fit? Sorry this will be my first F1 car. Kinda takign for granted everything to do with suspension is adaptable throughout
#323
foams on X1
i do not think foam is going to be a problem.
Maybe there will be not so much room to play with ride height.
I will check this later.
#324
these are the shims included for the rear axle.
#325
ride height
For the ride height on foam on the back,you can drive them off until 54 mm.
Your ride height will be 3,5 mm.
On the front you can not go smaller then 61 mm.
Ride height will be 3,5 mm.
So i think there will be a conversion for the front.
When you can lower the lower suspension arms 4-5 mm. it would be great.
It can be done very simple by using a smaller aluminium mount 376364-O
#327
