Xray X1 - Formula One Car
#2656
Tires
Just picked up a 2018 x1 and am new to on road. We are going to be running on new crc black carpet, what is the favorite tire for this carpet. Also you guys were talking about a spool, are you doing this yourselves or does someone make one.
Thanks, Tim. Great info in this thread!
#2657
#2658
#2660
X1 2019 so far...
1/12th style rear pod
Upper deck
New stiffer lower arms (possible front width adjustment too)
Upper deck
#2662
this is what google found
X1‘19 All-new features:
• All-new front lower arms redesigned for better durability, made from harder material, and possibility to adjust front track width
• All-new wider arm mount plate included in the kit to allow to adjust front track width
• All-new graphite top deck which allows to adjust inline chassis flex
• All-new alu servo mount to work with the new lower adjustable graphite arms
• All-new alu bulkheads allow for very quick & easy ride height adjustment.
• All-new upper clamps to work with new bulkheads
• All-new rear wheelbase adjustment
• All-new graphite rear brace with integrated backstop and O-ring battery mount system
• All-new O-ring for securing the battery
• All-new adjustable graphite battery backstop with 4 positions
• All-new graphite rear bulkhead brace with extra wing mount positions and redesigned to work with new rear bulkheads
• All-new plate for mounts to work with new top deck
• Softer, mostly used front coil springs included in the kit
#2664
#2668
Been thinking about adding an extra shim under the pin to take out some of that freeplay on that side also.
