RCHSR: Radio Controlled Historic Sportscar Racing
#181
On the McAllister Corvette DP body -
I measure the rear inside the quarter panels @ 200 mm and the front inside the wheel wells at 193mm (for those playing w/ ideas)
(speaking of which - I'm working on some decals for that body - not sure if I'll like the "wrap" style decal or not...but hopefully I'll have some printed up in the next week or two.
The Corvette is only 1mm narrower on each side than the PF Mulsanne, so it's definitely a good candidate, at least for some WGT chassis having a narrow front width. Alternatively, it's easy to take a few mm off the outside of the front tires on a tire truer.
I like the decals! Do you sell them?
#182
I've added the RJ Speed Porsche back on the body list in my suggested rules. On bodies such as this one with big rear kick-ups, we can require that the kickup be cut off and mounted higher on the tail fins as a wing. That will help a little with the scale appearance.
I've also added the Speed Passion LM1, in anticipation that it will work. I'll try to order when when it is available.
#183
In regards to WGT we all know who won out, just look at the approved body list or go see a race. What drives me crazy is that a body like the PF Gianna can be legal for the class-a fictional car that does not exist in real life, but a 200mm Ferrari 430 by Tamiya is not!
I also can't see Tamiya moulding the part number into the windscreen of their bodies and sending in several bodies, documentation and fees just to get ROAR approval for something that isn't going to make much difference to their sales numbers. In case you question the idea of having the part number moulded into the windscreen, it's there so it's easy to check it is an approved body, to make it easy for ROAR to check if a body has been changed, and to stop manufacturers bending the rules.
Here in the UK we don't do approval for the bodies and are more relaxed over our WGT body rules, so our list has 25 HPI bodies, including the GT40 and Lamborghinis, the Kyosho DBR9 and F430 and the usual Protoform bodies. The Parma DB9 is banned. Everyone still uses just the Sophia and Gianna. Personally I can sort of see how the Sophia could get in, but with the Gianna Protoform haven't even attempted to make it look similar to any full size car.
The front engined only rule in WGT is a case of a sledgehammer to crack a nut. It was put in there to make it impossible to use aero wedge bodies such as the Lolas used on 200mm nitro racing, without thinking about all the mid engined bodies that would be banned. Every rule has its consequences, removing the front engined part to allow the Ferrari 430 means it also opens up the rules for someone to make the Maserati MC12.
It doesn't matter how scale you want the bodies, the end result is that people will be racing against each other and the whole point of racing is to do as well as you can, whether that is winning a big meeting or just beating your friends.
There are not many of us who want to race just for the fun of it and just don't care about results.
#184
The class would still be pretty scale if Protoform hadn't decided to make a body for it, after all when it started most people were using the Protoform Corvette, although if Protoform hadn't made the Sophia no doubt everyone would have ended up running the Parma DB9
#185
Smaller companies that make bodies for racing are going to exploit the rules set forth by the rule makers-in the case of the USA it's ROAR. I don't blame them for that, I was stating what I thought the order of things were. There in the UK you don't have ROAR, and therefore you see more bodies from larger manufacturers whose bodies are produced more for modeling enthusiasts than just racers specifically. The body number in the window was a rule made for smaller manufacturers that produce bodies strictly for racing since a company like Tamiya or HPI is unlikely going to be modifying body molds to extract better aerodynamic performance. The consequence, intended or uninteded is that now only the racing car body makers a eligible for entry in their races. The rule about front engined cars in WGT I think was put in place to get away from scale realism by shortening the approved body list. To prevent someone using a Lola or GTP body you just put in the rules "no GTP or Wedge style bodies". To prevent someone from using a Maserati MC 12 body you do so by sticking to a body list or by adding that no GT1 bodies are allowed, only GT2 or GT3.
It all comes down to ROAR I guess not caring about scale realism. Maybe that's why VTA and USGT are not part of it.
#186
Test Results
I got a chance between races on Sunday to try the 17.5/1s combo. Here's what I ran:
Thunder Power 17.5
1s LiPo
Rollout 92 mm
Tires front gray 2.35", rear pink 2.43"
RJ Speed 962 body
SpeedMerchant WGT chassis
33 oz
The lap times were nearly identical (10.3 seconds) to my 17.5/2s touring car. To be fair, my touring car is not a front runner, and I'm better at driving pan cars. On the other hand, I just threw some tires on the WGTP, made no adjustments from the WGT setup, and only guessed at the gear ratio (I simply used the tallest gears I had available), so there's still improvements to be had.
The WGTP car was below my minimum suggested weight (38 oz.) by a large amount. I'll try adding weight next to see how much it slows the car down. I'm estimating that the final lap times will be between 17.5 TC and 25.5 VTA, or about the same as USGT.
Thunder Power 17.5
1s LiPo
Rollout 92 mm
RJ Speed 962 body
33 oz
#187
Personally I don't like the looks of the RJSpeed 962...looks too much like a 1/12 scale car. Until more bodies are compatible and realistic, why not pick a handful of bodies to start, and every 6 months revisit what to add and what to delete. Of course, having run Porsche Cup a few years ago, I happen to love the HPI Porsche bodies, but that's just me. I would think the Corvette and Viper bodies from HPI would also be ok since these cars actually run in ALMS races...
#188
#190
Its been quiet here lately.
#191
More test results!:
I got a chance during lunch break at last Sunday's race to try the 17.5/1s at Dee & Mee in Topeka, a medium-sized parking lot track. The track is very smooth, but abrasive. Traction was low to medium, with traction decreasing during the day due to wind-blown dust covering up the sugar-water prep.
The generator and computer are shut down during break, so I didn't get exact lap times, but I ran along with one of the fastest VTA cars and had no problem reeling him in, so I estimate that the WGTP lap times were about the same as my USGT car. The power seems just about right for the track and conditions, and the car was easy and fun to drive. I could break the rear tires loose out of the slowest corners, but I had to really try. Also, the speed on the straight was quite good.
#195
While not on the approved body list (at present), here are some bodies that are newly available in the US that may be of interest.
Viper
http://http://deltaplastikusa.com/in...product_id=139
Lotus Elise
http://http://deltaplastikusa.com/in...product_id=140
Maserati MC12
http://http://deltaplastikusa.com/in...product_id=155
Viper
Lotus Elise
Maserati MC12
