VBC Lightning 12 >
VBC Lightning 12
Like Tree3Likes
VBC Lightning 12
Old 06-25-2014, 10:04 AM
  #466
valk's Avatar
Dave had a pretty good ashphalt car last year for our race. Maybe he would share his setup advice? Brian bodine is also fast on ashphalt.
valk is offline
Old 06-25-2014, 11:16 AM
  #467
great thanks!!!
I hope they can help me out and share some setup sheets!
Mornedn is offline
Old 06-25-2014, 11:20 AM
  #468
Originally Posted by LloydLoar
Most of the VBC folks who respond regularly here on rctech are from North America, where we have very little 12th scale asphalt racing (unfortunately.) I think there have been some recent posts in the 12th scale thread about tire choice for asphalt, which is where I would recommend starting. Get the right tires, go from there.
I believe that with Pro-One tires we are recommending Orange rears (different than the synthetic orange Parma/Jaco used to sell) with Team Purple or Double Pink fronts.
My initial setup recommendation would be to start with the rear of the car soft (think like 15k tube lube, softest center spring you have, AE black sides.) Depending on how bumpy the track is you will likely also set ride height a bit higher, and you might also want to run a higher-downforce body like the Protoform TR-12.
Sorry I can't be of more help; we just don't have a lot of asphalt 12th racing here in North America.
Great thanks!!
Mornedn is offline
Old 06-25-2014, 11:21 AM
  #469
Originally Posted by Korey Harbke
^^^^ This is solid advice. Tires and traction additive are going to be your main changes. Pink or magenta rears with an assortment of pink, magneta, double pink and lylac are all tires I would initially show up with. I remember black can paragon followed by an application of suntan lotion if its dusty or hot out.
But as Chris mentioned, we don't really have the opportunity to run asphalt 1/12. Its always indoors in North America.
Hopefully that helps.
-Korey
Thank you!!
Mornedn is offline
Old 06-25-2014, 12:41 PM
  #470
valk's Avatar
Ill be running on ashphalt ina couple weeks so ill report back my progress. Starting with magenta pink/blue/green crc tires and a fairly soft setup.
I tried it with my old asc car and did black greylow which worked but wore very fast. i think crc pink/pink is where ill end up but im pretty poor and dont wanna buy more tires lol
I had prepped my mod tc but blew the esc, 12th scale was a last minute afterthought for a third class.
valk is offline
Old 06-26-2014, 11:32 AM
  #471
What's the best battery position? across the chassis or the length of the chassis?
Mornedn is offline
Old 06-26-2014, 12:58 PM
  #472
Trader Rating: 20 (100%+)
I found that placing the battery transverse (across the back) made the car easier to drive and more consistent. I know most other folks run it inline, though, so your mileage may vary.
LloydLoar is offline
Old 07-07-2014, 05:17 AM
  #473
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
Any update on a proper shock mount w/antenna holder?
dr_hfuhuhurr is offline
Old 07-07-2014, 07:25 AM
  #474
valk's Avatar
It definitely is easier to drive with more traction transverse. It does loose a little sharpness though and cornering seems to be more profressive.
I run it transverse most of the time but trying to work inline back in as my skills improve.
valk is offline
Old 07-07-2014, 10:35 AM
  #475
Hi guys.... What's the handling differences between caster on the kingpin angle vs the spacers on the kingpin?
Mornedn is offline
Old 07-07-2014, 11:20 AM
  #476
When you say 'spacers on the kingpin' are you referring to the upper hingepin (reactive caster)?
Spacers on the kingpin itself won't change anything to do with caster, they will just change spring preload.
Old 07-07-2014, 01:01 PM
  #477
Sorry I actually meant the upper hinge pin angel and spacers
Mornedn is offline
Old 07-07-2014, 02:25 PM
  #478
No worries.
The spacers on the upper hingepin are dictating static caster. The more spacers you have rearwards the more static caster, vice versa for shims moved forwards. Less static caster (shims moved forward) will make the car have more steering off-center, but less steering mid-out. More static caster (shims moved rearwards) will make the car a bit lazier off-center, but with more mid-out steering. I normally switch between either the big shim forward or the big shim back, but rarely use both shims back or both shims forward.
The angle of that upper hingepin is called reactive caster, and there are three different options for how that caster block is positioned: 0, 5, and 10-degree. Reactive caster is caster change through the corner and through the suspension travel. 0 would be 'old-school' with no reactive caster (so only static caster dictated by shims, as above). With 5 and 10 it really seems to be a matter of driving style, track, and personal preference. With reactive caster the kingpin will 'stand up' and caster will be reduced as the car turns and the suspension compresses, and then as the car straightens out the caster angle will increase again. For me, I think 5-degree typically feels the most consistent through the corner for mod 12th scale, but the 10-degree can feel pretty good too, depending on track conditions. Ultimately, I would recommend trying the different options for yourself and see what you prefer.
Old 07-07-2014, 11:47 PM
  #479
No worries.
Great, thanks for the help!
Mornedn is offline
Old 07-10-2014, 06:05 PM
  #480
valk's Avatar
Is there any plan to put a WGT car out this year? id like to pick up a third class for indoor that isnt 1/12 stock.
valk is offline
