3800-vs-3700 batteries
i think GPs cost more than IBs. GPs have been around a long time and they are proven batts.
IB are good for such a new company but i don't think their numbers are quite up there compared to GP but they are still good batteries.You couldn't go wrong with either.
Sean
Sean
At the Reedy race every driver that had a choice between the IB3800 and the GP3700 chose the 3700. The IB's are getting better but they aren't quite there yet ...I stress yet because IB is actively working on bettering their cells. Every shipment gets better. If they keep at it they will be on par with GP soon.
ive seen IBs exploded
Also The IB's don't like to get taken down past 0.9V which is kind of a problem for guys who tray there cells for longer periods or like to dead short. I have heard of people loosing 60sec of runtime and not have it come back after takign their cells past .9V. Just some more information. I have used the 3600's from IB but I did notice that they don't seem to last as long as my GP cells. I have stopped purchasing IB cells untill theycan take a over night stay on a tray.
Just my two pennies,
Stephen <><
Plus I noticed that there is more punch longer with 3700's. Just got another pack from promatch.
Stephen <><
Team EAM
Actually the IB's react very well to Deadshorting. I done a 4 cell pack and the numebers are below and are at 35 amps
361 Runtime
4.79 Average voltage (1.1975 per cell)
8.1 Actual IR.
They were right at 400 seconds originally and then after a few runs the runtime went down to around 380 then I deadshorted it. The voltage before was 4.73 and the IR's before were 8.6.
Still going to play with it some more but so far they seem to like it....
EA
361 Runtime
8.1 Actual IR.
EA
361 Runtime
8.1 Actual IR.
EA
361 Runtime
8.1 Actual IR.
EA
That is why there are sponcered drivers, so they can test all these batts for us mear mortals...LOL
Thanks EA for giving the other side of things.
Also did you get my PM regaurding the setup on 19T the two magnet setup? Will the other setup work with just two mags or will I need more than what we talked about.
Thanks,
Stephen <><
Adrian... I thought that the Reedy race didn't allow the 3800's just the 3700's... at least that was what was in the rules before the race on their website...
Actually I have started dead shorting my IB 3800's and it looks like they actually do like it. I'll try and post some number comparisons between similar packs dead-shorted and non-deadshorted....
As far as cells exploding... yes I'm sure they can if they are overcharged just like the GP's do as well...
So far I'm seeing that the 3800's like either a .03 delta peak on most chargers... some like a .04 on others. Right between 120 and 130 deg. F with a temp cutoff works well too. The biggest problem with a new cells is people assume they can charge it the same as brand X cell when the chemicals inside aren't the same.
Michael
Michael
Company Representative
Adrian M: Ralph Burch used the improved IB3600 to finish 8th at the REEDY race. He even won a few of his heats so performance of IB cells is every bit as good if not better than GP cells. Our track testing has shown us more punch with the IB3800 and extra capacity.
Michael
Michael
What kind of charge procedure are you using step or linear? And whats the charger being used?
Bye for now. Thanks
Gustav
I mainly use linear charging...
CE chargers... turbo 35, GFX, and pitbull seem to like a .03 peak detect.
on the orion advantage I use .04, but with a temp cut off around 48 C...
I've noticed that the temp sensor isn't exactly the same on every unit though...
Orion posted Hara's charging steps for the 3700's use my above cut off settings and try his steps... it's on their website...
Michael
Michael
