TA05 v1 VTA build: comments/questions/answers requested
#46
I Will Be Working On A Rebuild Of My Ta05 This Weekend. I Will Try To Post Pics As I Move Forward On it.
#47
And I'll be working my butt off packing and moving my 4BR house this weekend.. I'm interested to see and hear what you find rebuilding your TA05.
Keep the thread alive Bumpy
By the way, with 8mm wide hexes up front and 5.5mm wide hexes in back, my wheelbase is approximately (too big for my caliper) 191mm front and 197mm rear. That's outside edge of tire to outside edge of tire.
#48
What Does Everyones 05 Weigh In At?
#49
Got Th Rear Done. Out Side The Car The Dif doesnt Feel That Smooth ButInstalled It Is Like Glass. Added The Alum Gear Cases From 3 Racing. 45 WT Shock Oil And Red Springs.Rred Sway Bar. Middle Hole On The Shock Tower.
#50
Here she is pre tear down.
#51
All set up to wrench.
This was the cleanest it was all night. lol
#52
Rear end all tore off
- I didn't pull the center pulley. I had just put in some work on it. I had to grind down where the bearings slide in. The motor mount was squeezing the bearings causing extra drag. I used a dremel to grind it very slowly and checking very often so I didn't grind to much.
Fresh diff ready to go in
- I am using the Tamiya alum diff housings, alternated diff pulleys and the Tamiya HCCA diff balls. I have thought about stepping up to ceramics or switching to a gear diff.
- Sanded the rings using 800 sandpaper in a circular motion. about 40 times in each direction, alternating the direction every 10
- I use brake cleaner to spray everything off so there is no grit and it doesn't leave a film
All put back together with my new 3 Racing gear cases.
- I like how they fit plus they eliminate the extra piece for the bearing holder. They have a pin pressed into them instead.
#53
Tonight I Will Be Working On ThE Front End. It Seemed To Be Binding Last night. Also, I Will Be Starting In On Electronics. I Run A Flysky Gt3 Radio. The Receivers ARe Small And Only 7 Bux. The Novak Edge Esc And The Ballistic 25.5 Motor. I Just Picked Up A SpekUm S6070 Servo For It To Replace My Futaba 9550 That Was Starting To Show Some Wear And Went Into My Trf 201 Buggy.
Any Hints On Where To Start For Droop?
#54
What Droop Settings And Ride Heigh Settings Are Most Common For Ta05
#55
#56
Hey grizz. Are you using wider hexes?, what is your ride height? Droop?.
I just tore apart my ta05v2 ifs today to get it ready for the new season coming up so looking to improve. The series got ride of the fdr so now that's open. I found going into turns after the straight (100ft) I would roll if I was at speed. I took of the front sway bar and have been playing different springs but I am gonna start from scratch . I am running stock hexes, ball diffs front and rear as well.
Also running the 70 boss body
#57
Super Moderator
#59
TA05 are awesome chassis for the VTA class and I have seen them win plenty of times on big races.
I do have a suggestions for those who buy used chassis is to take everything apart and build it to the exact setup as the manual. This will provide you a great stock setup and will be very easy to drive. Though suggestions are great with the other people setups but that setup might not work for your certain track.
Once you have that stock setup then you can (very important) ONE adjustment at a time to find a setup that works for you.
Here is the manual link
http://www.tamiya.com/english/rc/manuals.htm
Have fun guys!
Have fun guys!
