Intellect Battery 3800 >
Old 12-19-2005, 10:36 AM
  #961
Company Representative
Danny/SMC's Avatar
Originally Posted by curious mind
yes sir, im fanning my batts while charging. is that bad? if so, whats the bad effect? tnx for the reply.
For a cell to charge properly it needs to reach its peak detect and temperature range naturally. So by cooling the pack down with a fan your not getting the desired chemical reaction thus not getting a full or proper charge.
Danny/SMC is offline
Old 12-19-2005, 11:24 AM
  #962
Danny, I always thought heat on any battery was bad. So I normally undercharge my batteries (ie. 3600 Mah in a 3800 pack), my batteries never got a aboce room temp, which I have always though was a good thing? or am I wrong.
David Alberico is offline
Old 12-19-2005, 04:19 PM
  #963
A Ilievski's Avatar
Trader Rating: 39 (100%+)
what discharge tray should i buy for my IB3800 matched packs. i was told they dont like getting discharge under 0.9v.
A Ilievski is offline
Old 12-19-2005, 05:43 PM
  #964
curious mind's Avatar
Tnx, for the reply guys, ill keep on reading post here in this thread for me to know more about the ib3800. till then.
curious mind is offline
Old 12-19-2005, 06:19 PM
  #965
I would go with either the wave tray or the Tekin,the .09 story is just that, a story,the Tekin will go down to .05 which is fine, but as far down as I want to go.
Hyper1 is offline
Old 12-19-2005, 07:25 PM
  #966
dougmartin's Avatar
Trader Rating: 14 (100%+)
Talking
I've been using my Integy 20amp tray for quite awhile with no problems. Your pack should not be discharged below 5.4v for the entire pack 0.9v per cell. If you use it more than once a day let it cool to room temp, then you should put on a tray for a few minutes before charging.
Integy also makes a 30 amp tray
http://integy.automated-shops.com/cg...26105291484.d5
And a 30amp dumper
Hope this helps
dougmartin is offline
Old 12-20-2005, 08:24 AM
  #967
teamgp's Avatar
Anyone have recommended settings on the pitbull X3 for 3800's? Thx.
teamgp is offline
Old 12-20-2005, 09:09 AM
  #968
Danny/SMC's Avatar
If your looking for the best performance out of any cell it needs to peak in the 130-140 farenheit range. Todays cells can easily handle that temp range and will perform at there best at that range.
Old 12-20-2005, 05:03 PM
  #969
josh69162's Avatar
I know this is a very relative question, but what does 135 degrees feel like to touch? Should it feel hot, but you can still touch it, or slightly warm? Or too hot to touch?
-Josh
josh69162 is offline
Old 12-20-2005, 05:12 PM
  #970
wvince's Avatar
Location: Tupperville, Ontario, CANADA - like tupperware but with a population of 450.
Depends how think your skin is....
wvince is offline
Old 12-20-2005, 05:17 PM
  #971
XrayFK's Avatar
-Josh
It should not be too hot to touch. Keep in mind that you are already around 98 degrees.
XrayFK is offline
Old 12-20-2005, 05:22 PM
  #972
whynot's Avatar
Trader Rating: 18 (100%+)
What if they finish charging at110 degrees or 150.And how soon do you have to run them after they are done charging?
mike
whynot is offline
Old 12-20-2005, 07:46 PM
  #973
Danny/SMC's Avatar
At 110 they will not give the maximum performance. At 150 they will perform well but could potentially hurt the life expectancy of the cells.
For best results run the packs as near to the end of the charge as possible.
Old 12-20-2005, 08:12 PM
  #974
x-ray=speed's Avatar
is there a problem with charging the pack the night before a race meeting and then re-peeking at the track just before the race
x-ray=speed is offline
Old 12-20-2005, 11:54 PM
  #975
PitCrew's Avatar
Mainly, the performance is going to SUCK!!
Secondly, and maybe Danny can correct me if I am wrong, but you may risk acctually overcharging the pack. Since the pack is cold, but charged less than 24 hours prior, it is still relatively well charged. But, the charger probably wont detect a peak untill a relatively large amount of current has passed through the cells. So, you could overcharge them. AND you want them to be warm and right off the charger right before your race.
Whats better, a day old cold donut, or a nice fresh warm KrispyKreme??
PitCrew is offline
