Schumacher Mi5
#1081
ran my first race today with my mi5 it's super responsive and easy to drive and had zero issues with it car carries a ton of speed through the corners
#1082
Trader Rating: 102 (100%+)
Ohhh.. there is ONE issue I noticed today. With my belt on the loosest setting (not actually the loosest, but as loose as I want to run with no slipping). The rear belt actually drags on the bottom aluminum of the motor mount! It actually polished the edge shinny, and I think is part of the overheating issue I have been having. I tighted up the rear belt one notch or so, and it seems to clear it a little better. I think I might have to file down part of my aluminum! I didn't even notice this until today. Anybody else that runs a loose rear belt notice this?
I would recommend to run in 3 slot, belt should loosen after a few runs (same belt rub with cxl).
Build Tip:
If you run front in lowest setting it may rub the front plastic battery positioner. Flip standoff upside down or remove.
#1083
Yes in low setting 1 and 2 belt will rub lower motor mount standard.
Build Tip:
Build Tip:
#1084
1.) The Mi5 was a monster today in 17.5 Took all 3 quals and the main today, a lap and half on the field. The car was fast, planted, great balance, zero issues.
2.) So I finally figured out what the "tick tick tick" feeling is as I compress the rear arms of my car (and I noticed it does it a TINY bit up front too). Last I left off, I figured it had to be either the screws from under the chassis were tightened too tight into the pivot balls for the arms, or the pivot ball itself is just catching on the plastic insert in the arm (some kind of friction right there).
So I busted out my light bearing oil, and put tiny drop where the ball meets the plastic bushing/gromit... ran the car 1 run... and the "tick tick tick" is completely gone. booya! There must just be a tiny bit of friction that catches and lets go between the pivot ball, and the bushing that is glued into the arms. The drop of oil did the trick. (im glad it was such an easy fix)
3.) I am now running the 14x4mm screws up into the turn blocks, and MAN what a difference. Those of you just getting this car together, get a set of of those screws and don't even bother running the stock 4mm bolt thingy that comes in the kit. The 14x4 screws feel like they work twice as well as the stock pieces. I don't think we will see many more stripped turnblocks with this mod in place.
4.) Was great pitting with you today, Jaybee. Your car got faster and faster each run throughout the day... bummer about the broken aluminum chassis screw screw in the main.... You were rockin 2nd place for quite a number of laps there. Not too shabby, my man, considering how long it's been since you have been out racing, and in open mod to boot! You will be a monster by next season for sure.
Your MI5 "shorty" setup is beast right now! TQ'n every run...NIICE! Glad to help with those kingpin screws, they make a difference; and paired up with the running change blocks...can you say stout frontend?
Setup changes respond nicely on this rig. The car is in pieces atm...a fresh rebuild is coming. FASTTRAX is in 5 days.
SAVE DEM TYRES!!!
#1086
#1088
still looking for the springs #'s
I received my kit today, and as everyone stated it looks great!!!!!
(I don't have the updated parts, but I do have the mods....)
I want to thank everyone who posted setup sheets, and mods for this kit!!!
you are ALL a CLASS ACT!!!!
next step is to start the build!!!!
#1089
http://www.amainhobbies.com/product_...ck-Rebuild-Kit
#1093
Anyone there has to much play between there wishbone and the caster blocks in front ?
In the back there was shims to be put in between the caster blocks and wishbones, but not in the front ?
Did anyone have the same issue about the front belt rubbing on the servo mount screw ?
#1094
hey guys,
Yokys-14575L
#1095
