Schumacher Mi5
#1036
the schumacher kit are linear, the spec-r listed in the manual are linear. are the yokomo progressive?
and xray 2.8 and a spec-r 2.8 is the same isn't it?
the same rate with different combinations of wire thickness and number of coils and create a spring that has completely different characteristics.
#1039
Build is coming along nicely.
#1040
Quality is very good.
#1041
#1043
Completed a full race day with this kit on Thursday.
All I can say is that if this kit did not drive so well I would have it for sale RIGHT NOW! I stripped out 3 steering blocks in 3 races and 2 practice runs! This is unbelievable.
Does anyone know of any aluminium blocks?
Until they are released I am going to try some Helocoils and a servo saver, If they do not work this kit will be sitting gathering dust until aluminium steering blocks are released.
#1044
Sounds like a saver would help a ton
#1045
#1046
In response, yes the Yokomo springs are progressive. Pink for the front and blue for the rear. I also have the next yellow and green which are the next harder spring just in case I need a firmer set of springs.
Later,
Calvin.
Later,
Calvin.
#1047
after that you will love this car for BOTH the handling and the durability
#1048
+1^^^
+1 ^^^
(get a couple x-tra packs of those flanged jobbers)
Don't worry about heli-coils. use the 14mm screw, don't bother with the set screw and watch the flanged caster block bearing as hard enough hit and you will break the flange right off.... been there.
#1049
Maybe an stupid question, but how do you make your shocks without any rebound. When I compress my shock piston all the way in, to avoid any rebound, then the shock piston shaft is almost at the top, and there is no room for putting the diaphragme in, without it pushing down the piston. and then I am afraid that there will be rebound in the shocks ?
#1050
