Schumacher Mi5
#2506
Has anyone tried the new steering rack yet
#2507
#2508
#2509
I've tested the new steering last Saturday on carpet, better feeling also for me with the unit, the car is more consistent.
This weekend I hope to test it on asphalt
#2510
Is there a weight difference did they get it to be lighter as well if so all the better
#2511
What spareparts should I have in my pitbag for the "old" Mi5? Going to my first race with this car soon.
Which parts break easy, and what wears quickly?
The only thing I have broken myself is the steering rack (twisted out of bearings in a crash).
All inputs are appreciated!
#2512
Kingpin only weak point Broke one after many crashes but when they do u might loose the bearings it passes through and sometimes u need dremel to get the kingpin out out the hub and that's not always in ur tool kit at the track
#2513
Thanks man
#2514
#2515
Cheers guys
#2517
will the new steering rack work on a mi4cxl?
#2518
#2519
i have the twin point steering but i was wondering if the elevated steering system for the servo and all the hardware will fit?
the complete bracket and everything?
#2520
for my mi4cxl can i put the center bracket for the steering as is in the first pic. the reason I am asking this is because with the mi5 steering arms. they are causing my center stear to be to far forward. I also like the looks of the evo system over the cxl. also the steering arms are longer then the standard mi4cxl with no adjustment. Is there a shorter arm option? thanks for the replys!
