Team Durango DETC410
#1547
RW spur gear are machined and very thin. one of the best spur gear manufacturer IMHO
#1548
Thanks guys. I'll order the panaracer at TQ.
#1549
Jeff
#1550
Looking for the front outdrives for a front diff. Let me know what you got.
#1551
Diff Quesrion
Can you use the DETC V2 diff in the V1 car?
#1552
i belive so..the main difference between the v1 and v2 were stronger plastics...i'm working on an a "v3" in my head right now
#1554
making a mid motor chassis,low friction belts different steering knuckles so i can actually run vta,lowered shock towers,ultra short shocks and new upper deck
#1556
I was toying around with this idea as well but then decided to just buy an MTC2 instead. I may still do it for fun as I have a ton of parts and an extra un-built V2 kit. I already run low profile shock towers and a redesigned top deck but I may build around a 1 piece motor mount like the newer cars and go from there as long as the diff and spool line up correctly with the drive pulleys.
#1557
detc410
#1558
What low profile shock towers did you use ?
#1560
yodog,ygpm
