Old 03-18-2013, 12:47 PM   #1
NItrox416's Avatar
Default Trinity 13.5 Maxzilla: fdr?
Hi all,
I'm searching for a good starting point fdr and timing for this motor, I run in a small truck and I arrive to 4 fdr with o timing on endbell but the motor has a weak acceleration and it's still cool. I'm running touring blinky.
Any suggestions?
I should go even more down with fdr?
Thank you very much.
NItrox416 is offline   Reply With Quote
Old 03-18-2013, 01:12 PM   #2
mkiiina's Avatar
Trader Rating: 69 (100%+)
How does your speed compare on the straight? What is your current gearing?
mkiiina is offline   Reply With Quote
Old 03-18-2013, 01:50 PM   #3
Trader Rating: 1 (67%+)
The timing should max out somewhere around 24 degs on the endbell, that is where I would run it.
FDR on a small track will be around 4.5 in a tc.
You will want to use a fan on the motor and check the motor temp after a minute or 2.
Turning the timing down will help with temp if its getting hot.
Josh Hohnstein is offline   Reply With Quote
Old 03-18-2013, 02:14 PM   #4
NItrox416's Avatar
It's hard to say because the straights are very short approx 20-25m however I was a bit faster in the end, just before the brake.
The gearing is 3.97 with 0 timing
Old 03-18-2013, 02:26 PM   #5
locked's Avatar
Do as Josh suggested. Start around 4.5 FDR and crank up the can timing. It should give you faster acceleration and probably won't lose much top speed.
locked is offline   Reply With Quote
Old 03-18-2013, 02:34 PM   #6
NItrox416's Avatar
But my endbell has only 20 deg of max timing. I will try 4.5 fdr but temperature, also with 3.97fdr, don't seem to be a real problem. Maybe because I was setting improperly my motor?
Thanks everyone for help
Old 03-19-2013, 07:52 AM   #7
NItrox416's Avatar
NItrox416;11944891]But my endbell has only 20 deg of max timing. I will try 4.5 fdr but temperature, also with 3.97fdr, don't seem to be a real problem. Maybe because I was setting improperly my motor?
Old 04-01-2013, 03:58 AM   #8
pierre johnson's Avatar
Location: im from cali but lived in texas most of my life
I have 5 dgrees end bell. Timming with a mod race profile has given me enormous top end and plenty of bottom end..
Team Rctarget /Capricorn America/Reds Racing and Hobby Recreation Products!
pierre johnson is offline   Reply With Quote
