Shock position again?!
I experienced the shock position on shock tower.
On the front:
If move the shock position inward (more laid down)
less turn in
more mid and out of corner
If move the shock position outward (more standup)
more turn in
less mid and out of corner steering
On the rear:
less turn in rear traction
more mid and out of corner rear traction
more turn in rear traction
less mid and out of corner rear traction
That is what I experienced but how come in the Xray setup booklet. It says more front laid down shock will have more turn in? What seems to be wrong?
On the front:
less turn in
more turn in
On the rear:
I wouldn't trust the XRAY book. Lots and lots wrong in it.
Your observation is pretty much correct. A stood up shock will be effectively stiffer at the wheel, and stiffer settings give more "response" (initial turn-in), but less "grip" (mid-corner).
There is also a small effect on the progressiveness of the wheel rate the more the shock is angled, but since very few cars use extreme angles I doubt it would be something you would notice. It is relevant to something like the old Schumacher Cat 2000 which had almost horizontal shocks.
