Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 07-20-2015 | 12:26 AM
  #751
Djchow85's Avatar
Get the s version. It would be interesting to see time differences on the track both cars.
Djchow85 is offline
Old 07-20-2015 | 03:05 AM
  #752
A type S article will be done soon, as I am taking one to a national race event to see how it fairs
Qatmix is offline
Old 07-20-2015 | 03:54 AM
  #753
Djchow85's Avatar
To the one deciding on which TT02, if you have experience, try get a sensored motor. I'm not sure if it's the tightness of the drive train (of the tt02)or my sensorless motor but having a race grade buggy plus sensored you're driving something completely different in terms of engineering design and feel
Djchow85 is offline
Old 07-20-2015 | 04:34 AM
  #754
I just got the type R after being "sweet talked" by the shop people
the type S was OOS
novaris is offline
Old 07-21-2015 | 12:48 AM
  #755
non-sensored motors are known for cogging at very low speed or when you are starting to pull the throttle trigger, could be the cause of that feeling of "tightness" on your tt02's drivetrain.
voodoo is offline
Old 07-27-2015 | 10:04 AM
  #756
Bought a tt02r for my 10yr old son. He likes doing laps with me down at the local on road track. Thought about getting a tt02s kit also and build one uber tt02 and one beater. Take all the best bits out of the two kits and build a TT02RS?
76jimmy is offline
Old 07-28-2015 | 12:33 AM
  #757
I studied the manuals for the s spec as I have the r spec as i had the same thoughts as you
generally speaking, you can but there are some issues.
the s spec and r spec's suspension setup is quite different,
r spec uses a double wishbone system. s spec uses a single lower wishbone with camber adjustments.
the s spec allows for camber adjustments while the hop up option for the rear knuckle is set at 2.5degree. though there are option parts (rear metal suspension plate) that seems to allow for 3degree toe in.
the s spec cannot use the r spec's 3 deg knuckle because the rear suspension setup is very different.
the R spec should be able to use s spec's front camber adjustment by replacing a number of parts from s spec.
of course there are aftermarket options from yeah racing etc.
YR might have option parts to give 3deg toe in for the rear knuckles.
I am getting some upper suspension arms that allows for camber adjustment to fit into the r spec that I have.
novaris is offline
Old 07-28-2015 | 06:36 AM
  #758
I ordered both kits. I'll play around with the parts see what I can mix and match.
76jimmy is offline
Old 07-28-2015 | 06:42 AM
  #759
Trying to find a set of swing shafts for the S version. 42mm is what the dog bones are so does that mean I need 42mm swing shafts? Only 42mm swing shaft kits I could find were tamiya# 54515 for the xv01. Do you guys think they would work for the tt02s?
76jimmy is offline
Old 07-28-2015 | 03:02 PM
  #760
The tamiya TT02s manual recommends the XV01 front (42mm) universals.
Qatmix is offline
Old 07-29-2015 | 04:18 AM
  #761
Cool that's the kit I ordered. Thanks!
76jimmy is offline
Old 08-02-2015 | 12:32 PM
  #762
When using the XV-01 universal shafts (#54515) in the front of a Type S, I found that a spacer is needed between each of the (top) 5 x 9mm ball connectors (BB5) and the F1 / F2 parts (#51293) so that the ends of the ball connectors will not foul and dislodge the wire retaining clips on the universal shafts when the car is in motion. I used a 0.5mm thick spacer on each ball connector, although thinner spacers may suffice.
atg849 is offline
Old 08-03-2015 | 01:23 AM
  #763
Originally Posted by Franjo
I'm really tempted to buy this kit since it's so cheap. I've never built a car at all. What is the build like on the TT02? I assume simple? How long does the build take? I've read that anyone could build the TT01s.
I got my first RC car a couple of months ago, it was a RTR. I've read through the build and review of the TT02 on this site as well and I'm thinking $130 bucks for this car with shipping could be worth it.
I know I require a servo but I don't know which one to buy as again I'm new to the hobby and am still reading lots. Id like this to be a drift car. I think I'll price out some hop ups and see what this comes too. After the initial purchase, I don't think I'd ever add anything to this car again. I think it's more for the experience of building one of these things
Took it only a couple of hours to build, 2 hours I guess, max 3. It's very easy to build even for a beginner.
Like another user said, the body is harder. It requires careful spray painting to avoid the paint becoming too heavy.
kristianecyrus is offline
Old 08-06-2015 | 09:05 PM
  #764
In case anyone was wondering what the stock f/r camber, and front toe are on the regular tt-02s:
Front camber: -1°
Rear camber: -1°
Front toe: +1°
Pretty sure I couldn't find this info anywhere when I looked a while back, but I've got a well-shimmed type-d on the setup station, and it's solid 1s everywhere. I have the 2.5° rear toe blocks, so not sure what the factory rear toe is.
Hayling is offline
Old 08-08-2015 | 02:52 PM
  #765
Bri
Is it possible to compete at the local level with a TT02R in a 21.5 USGT class on an outdoor asphalt track? I really like Tamiya products and was wanting to do some touring car racing on a budget. I wasn't sure if the TT02R could be competive or not against more race worthy touring cars. Also, which car do you think would do better a stock TB04 or a TT02R?
Best regards,
Brian
Bri is offline
