Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 04-27-2026 | 09:27 AM
  #4171
Aaron P's Avatar
Originally Posted by IceBreakerCB
Does anyone have a fix for the spool on the SRX? Mine keeps breaking, even on the lightest taps. Is there an upgraded version available, or a better option people are running?
I'm running TAM22047 without issue. Something you could try is to back your dual rate off just a couple of clicks to just before full lock to provide just a bit of give.
Aaron P is offline
Old 04-27-2026 | 11:25 AM
  #4172
Monotremata's Avatar
Originally Posted by Aaron P
I run the Gens Ace 6100's full size. They are LCG and just the right weight to where I only need to add about 5 grams to make the 1400 minimum weight. You can run shorties, but I've found that balance is better with full size packs.
I ended up going with those ones too. Its funny, ordering direct from GensAce, you can only buy singles, but I got a two pack sold by them through Amazon for about $150. They threw a bunch of strips of foam inside the packing box that are about the exact width/length as the full size packs. This stuff was the perfect size, if I had it prior I would've just made a decent block to use my shorties.. It came in handy though, the full size batteries still move side to side a little in the tray, just cut a couple strips and used some of the leftover double sided tape from the body and voila. Now that thing is nice and tight and pops right out when I need it to!
The 6100s are only like 2g heavier than the 5000. Not sure why anyone would bother with those, might as well go with the extra power just to be safe!
Monotremata is offline
Old 04-27-2026 | 03:44 PM
  #4173
Raman's Avatar
Going to try my hand in LMH class with this.
Raman is offline
Old 05-03-2026 | 01:29 PM
  #4174
Default Tamiya TT02F announced
Here is a little project I have been working on.
I wanted to race in the frontie class at my club, but there wasn’t a suitable Tamiya so I made one. 😎
The files are free to download and I will keep tweaking them when I get feedback.
Hope some of you like it https://www.thercracer.com/2026/05/t...oject.html?m=0
Qatmix is offline
Old 05-07-2026 | 08:06 PM
  #4175
Raman's Avatar
Aaron P and YoShImUrA53 like this.
Raman is offline
Old 05-08-2026 | 04:10 AM
  #4176
simple's Avatar
Originally Posted by Raman
Is that the Hyrax?! Facepalm
In my experience, thus far, and outside of the Bwoah, the only LMH body that will properly mount on a TT-02 is the new Bitty 499"T"
The vast majority of the LMH bodies on the market are only compatible with the modern ultra low profile TC chassis that have the shock mounting positions below the the level of the tops of the wheels.
Even my TA08Pro required custom shock towers to get the Hyrax at proper height.
My friend, you were either lead astray, or boldly leaped.
Raman likes this.
simple is offline
Old 05-08-2026 | 06:16 AM
  #4177
Raman's Avatar
Originally Posted by simple
Is that the Hyrax?! Facepalm My friend, you were either lead astray, or boldly leaped.
I had my suspicion it was going to be an issue on the TT02 and considered getting the 599R.. but I am a Porsche man, so I picked up the P963 which I had planned to decorate with the 1997 Mobil 1 livery. I tested it on my TRF421 and the rear body posts remain an issue.. vertically they sit right at the start of the fender curves. Horizontally you need one of those internal drop down carbon mounts. Need to figure out which one.
Raman is offline
Old 05-08-2026 | 07:08 AM
  #4178
gigaplex's Avatar
What about the Montech range?
gigaplex is offline
Old 05-08-2026 | 08:41 AM
  #4179
Raman's Avatar
I looked into SSBB shock towers. Most have the eyelet for the body post. if those were deleted, the body could be dropped an additional 8 to 10 mm.. which would be passable. For rear body posts, you could use the spare bumper on B parts.. and use vertical body posts.
Raman is offline
Old 05-08-2026 | 09:21 AM
  #4180
simple's Avatar
I can't speak to ALL of them, although Montechs marketing does specify "can be mounted on all the latest generation Touring Car chassis".
Its possible there might be a few that happen to clear mechanics of the good'ole TT-02, but I wouldn't bet money on it.
All I'm saying is that I know for a fact that the Hyrax won't clear the shock towers of older design, and thus far, Bitty has been the only company to precisely specify that their LMH 499 "T" body will fit the TT02 without modification or creative tinkering.
simple is offline
Old 05-08-2026 | 09:33 AM
  #4181
Raman's Avatar
Bitty did right to build a TT version of the 599. Maybe they will follow up with the other releases that are coming, eg. Aston, Toyota et.
I asked Bitty about a Porsche 963.. they said they had no plans to do a Porsche..
The track in my area that run LMH are quite big. So the 25.5. motor doesn’t inspire me to dedicate a more advanced chassis to this class.
angrymelon and simple like this.
Raman is offline
Old 05-09-2026 | 06:56 AM
  #4182
I picked up the hard chassis this week and was planning on moving everything over and at the same time switching out to hex hardware. I picked up this 520pc 'RC screw kit' awhile back and realized I have most of the screws I need to do it already. Amazon's delivering the suspension pins today, so don't have to worry about those funky screws. So far, the only hold up are the 3x15mm screws that hold in the bumper plates.. I've got some 3x16mm, but is that extra mm going to be too much? Should I be safe and go pick up a few 3x15mm machine screws instead? Don't have any of those hex head screws either but eh those are only for the body posts and the front spindles so I can leave those I guess.
I was about to get started at like 6:30 this morning since I was awake but ran into that while I was looking through the manual and comparing what I had available heh. Didn't want to ruin my new $8 chassis haha.
Old 05-09-2026 | 07:54 AM
  #4183
Raman's Avatar
If the bumper screw is too long, it can create a dimple inside gear box which will rub on the diff ring gear. To be safe you can put a 1 mm washer on the 3x16.
Monotremata likes this.
Raman is offline
Old 05-09-2026 | 08:05 AM
  #4184
Haha perfect, got a whole bunch of blue AE 1mm and 2mm washers ready to go. Don't want to risk messing up my oil filled diff and coupler! Ordered a pack of various socket head hex screws too, so now I got the hex head screws covered, those should be here tonight at some point.
Now I got my 3mm and 5mm shims, hard chassis, and a fresh pack of USGT tires (TQ RC was out of the belted ones ). Time to switch over the chassis, get rid of the remaining slop, and go back through and make sure I loctite everything that needs to be this time just to be safe.
Just discovered the Cal Raceway down in Orange last week too. Might have to go pick up a 911 GT3 R body now so I can get some practice in their Porsche class before the TCS at Revelation next month heh.
angrymelon likes this.
Old 05-12-2026 | 06:32 PM
  #4185
can a base tt-02 be converted into the tt-02 srx? if so is there a kit to start with or a list of what parts would be needed?
JustinL7294 is offline
