Tamiya TT02 Thread
#196
Tamiya will be releasing reinforced steering blocks in the next couple of months, only question is when.
Thereinforced steering blocks will be included in the new TT-02D (drift) version kit.
#197
Maybe all the new stock of TT02 kits will just feature them.. Hopefully the will be just on the Parts tree
#198
I put the late TT01 steering blocks on the TT02, not a big problem.
Just need some spacers. Will take some pics for you all and my race collegues.
That will maybe help, until better steering blocks are available by Tamiya!
Br,
Matthias
#199
#200
I don't understand why steering blocks would be an issue. Maybe people need to practice more or get out of the hit anything that moves novice/rookie classes?
I know accidents still happen in the higher skilled classes, some people just drive too aggressively.
So when you break these is it because -
Its not really a concern, I don't remember the last time I actually hit something with an R/C car and I haven't driven one in twenty years, besides a hot rodded X-Mod indoors and still didn't hit anything...
- Impact from another car?
- Impact to the boards/fire hose/pvc pipe?
- Other impacts from the side?
#201
I have only broke one in over 6 months and it was a large impact (So acceptable to me). I'm not an agressive or novice driver but any form of racing has its accidents.
It's the only part that's broken and that's fine as everything breaks at some point. However as also mentioned here others have had more breaks with light collisions. That's not good for a kit that's aimed at all levels from beginners upwards.
It may be because we had the first batch, but as tamiya has acknowledged the fault with new parts its safe to say that they needed a revision going forward.
#202
Since there are no rally bodies coming on the TT-02 I really want, I have looked into getting the semi-assembled chassis as I mentioned before.
No matter what happens though, the outcome is still the same in regards to price.
Banzai - $228 (Subaru 2008 WRC body)
RcMart - $241 (Exo Body)
The price difference is because Banzai charges less for the chassis ($101 vs $119) and slightly lower shipping charges from RcMart (Hong Kong vs Japan).
That not out of my budget but its more than I wanted to spend. That includes bearings and CVA shocks because to be frank pretty much every car is coming with those, but Tamiya.
I can get the Kyosho Fazer Rally car for $202 out the door, RTR. While I can't run the TCS with it and maybe Kyosho parts are expensive + hard to find, I think I can live with that, still thinking it over.
#203
Since yesterday I can call a TT-02 my own, too
Bought it with the Porsche 911 Carrera RSR body - I love it!
Started to build it yesterday and equipped it with bearings, the aluminum propeller joints (54502), the aluminum propeller shaft (54501) as well as the CVA mini shocks (53619).
Haven't finisehd yet, but I'm excited to
#204
Does anyone have any idea if the Tamiya kits that Banzai Hobby sells come with an ESC? The Tamiya website says the kits come with TEU-105BK but the Banzai website shows that it doesn't. EVERYTHING else is exactly the same including model number. I've tried contacted them but haven't received a reply so thought I'd ask here.
#205
http://www.modelbouw-aktueel.nl/page...-tamiya156.php
#206
It seems to be something with only the export kid builds cominging with an ESC...
Cheers,
Crouch
#207
Just thought I’d add my 2c here comparing the TT-02 platform and drivetrain back to its predecessor, the TT-01.
My previous RC was a TT-01 drifter and so far I’ve built three vehicles of the new TT-02 platform – one drifter and two buggies.
Many people have commented that the TT-02 has not improved on the TT-01 because it does not come standard with features like bearings, oil shocks, etc., and I certainly agree in the case of bearings in particular.
But one thing that I think hasn’t been highlighted enough is the improvements to the actual design itself, vs the TT-01.
Some examples include:
* It’s much easier to work on with the diffs dropping in from the top, rather than the sides – you don’t have to tip it on its end or remove the lower suspension (I switched out a diff the other day on my driveway in 5 minutes just by disconnecting the suspension and steering and unscrewing the top of the diff housing)
* It’s much easier to attach and remove the suspension, uprights and knuckles because they’re not held in place by the diff covers
* Drifters no longer need to cut away parts of the chassis to achieve maximum steering angle
* There are fewer gaps and holes underneath, making it much better suited for offroad use
* The suspension arms are set for maximum movement droop, without needing to cut anything away
* The main driveshaft is a sturdier design and is much easier to install as it drops straight in – Your not poking it through the sides of the diff housing
* The ends that connect into the diffs from the main driveshaft are identical at either end reducing confusion
* The tub can now fit hard case LiPo’s
* Everything seems much more rugged and sturdier
And I’m sure there’s more.
So while it may not have additional features included, the core design itself is much more user-friendly to use and maintain vs the TT-01.
Just my 2c.
Cheers,
Crouch
Just my 2c.
Cheers,
Crouch
#209
The TT02 is better in every single way to the TT01. TT01's also came with bushings and friction shocks, its only the Drift versions that had oil shocks and bearings, Tamiya has a drift TT02-D which will be released soon that will have these included.
#210
I was going to get these hop up parts from Banzai:
54476 TT02 Ball Bearing Set
54558 TT02 Aluminum Motor Mount
54501 TT02 Alum Propeller Shaft
54502 TT02 Alum Propeller Joint
54539 TT02B Full Turnbuckle Set
51527 TT02 A Parts - Upright
51528 TT02 B Parts - Sus Arm
51529 TT02 C Parts - Cup Joint
51530 TT02 D Parts - Motor Mount
Can someone please tell me if something here is unnecessary or of there is something else I should get? I'm getting the spares just cause they are kind of cheap but if you guys don't think I need them I won't buy them.
I was trying to decide between the TT02 and a used TB03 but I think the TB03 is a bit too much care for me at the moment and I think I'd like to try racing in the novice Tamiya class.
Also, can someone tell me how fast the stock motor is in the TT02 kit? The description just says 540 brushed motor but i'm not sure how many turns or anything like that.
