Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-02-2019 | 11:08 PM
  #2011
i just got a tt02 just to do some backyard drift bashing. ordered a diff lock. does it go to the front or the rear? i maybe also want to get into circuit racing? what are the benefits of the diff lock?
r_torres is offline
Old 05-02-2019 | 11:26 PM
  #2012
Rear for drift, front for circuit.
Bloke is offline
Old 05-02-2019 | 11:46 PM
  #2013
With the standard 'open' gear diff, more power is sent to whichever wheel is easier to turn. So in low traction conditions it will send almost all the power to whichever wheel has less traction, making it spin faster, and minimal power is sent to the wheel with more traction. You're probably familiar with this when 2 wheel drive car does a burnout and only 1 wheel spins - this is because it has an open diff.
When you install the lock block both wheels turn at the same speed regardless of traction. So under low traction conditions the car is able to break traction at both wheels simultaneously. If you put heavy grease (e.g. tamiya AW grease) on the internal diff gears then you can achieve a 'limited slip' action which is somewhere between locked and open.
For drifting, you want to put the lock block in the rear and have the front diff as open as possible (minimal grease on gears). This will allow both rear wheels to break traction and the rear of the car to slide, meanwhile the front will spin 1 wheel and generate minimal forward traction which would otherwise cause the car to straighten up out of a slide.
For racing, you want to put the lock block in the front and have the rear open. This makes for a handling characteristic which tends to understeer rather than oversteer, making it easier to control. The car generally goes in whichever direction the front wheels are pointed and the rear does not easily slide since only 1 rear wheel will break traction if too much throttle is applied.
nbTMM is offline
Old 05-05-2019 | 09:55 PM
  #2014
thank you so much for the great information. can’t wait til the diff comes in. after watching all these videos on youtube, i think i’m more towards leaning to circuit racing. looks real fun.
dampers looks like the next mod for the tt02. anyone have suggestions? i was looking at the trf big bore dampers 42287. suggestions welcome.
r_torres is offline
Old 05-08-2019 | 06:22 PM
  #2015
snowmiu19's Avatar
TT-02 Gear Diff. The pic seems like missing some parts? a cross pin and 2 more satellite gears?
snowmiu19 is offline
Old 05-08-2019 | 07:06 PM
  #2016
Raman's Avatar
nope that is the diff. You don’t necessarily need 4 satellite gears. You can choose to add them however
Raman is offline
Old 05-09-2019 | 06:46 PM
  #2017
I just finished building mine and also thought it was missing two gears but I trusted the design and built it. Seems to work the same as those with four small satellite gears, like the tt01, m07, even X-ray. But why would you choose to add the second set?
ebohon is offline
Old 05-09-2019 | 07:58 PM
  #2018
MidwestRacer's Avatar
I find it interesting the Oil filled diff has 2 gears but the stock non sealed diff has all 4? Granted the stock tt02 has plastic gears, but how much would it actually cost just to include the 2 gears and cross shaft?
MidwestRacer is offline
Old 05-10-2019 | 10:32 AM
  #2019
wtcc's Avatar
Just some dollars, not much. But I would not recommend this differential at all! It leaks badly, it isn‘t smooth at all, the metal gears dye the oil grey, it is the worst gear diff I have ever owned. If you have the chance, buy the 3racing gear diff for the TT02. No leaking and smooth running.
rippen likes this.
wtcc is offline
Old 05-10-2019 | 11:36 AM
  #2020
proliteandsc's Avatar
Anyone know how to keep the stock aluminum pinion gear from wearing out? I can't change to a different kind. It has to be that one. Used kit tamiya grease on one car and real car synthetic bearing grease in another car. They both lasted about 6 races. Should I not use any grease?
proliteandsc is offline
Old 05-10-2019 | 11:38 AM
  #2021
They seem to not care... I'd just use another same size pinion. I run mine dry, and they last a lot more than 6 races.
Nerobro is offline
Old 05-10-2019 | 11:50 AM
  #2022
Raman's Avatar
Agree with Nerobro. There’s no need for grease on pinion.
Raman is offline
Old 05-11-2019 | 05:36 AM
  #2023
3racing diffs are a much better option, mine are still leak free and running smooth
rippen is offline
Old 05-11-2019 | 07:21 AM
  #2024
Raman's Avatar
Come now .. those gears need breaking in .. the casting dates back to 1990s lol.. made out of unobtanium pot metal.
They should not have included metal gears at all.. should have stuck to nylon, derlin like other kits
You probably can sub the internal gears from another kit. I need to get my hands on one to figure out which kit.
Raman is offline
Old 05-11-2019 | 08:51 AM
  #2025
What pitch are the gears?
