Checkpoint motors
#406
Doesn't make a difference though. Still gonna be one of the best 19t out there.
#407
I got to see a Checkpoint 19T at the Snowbirds. Once you see the endbell you won't be concerned. The molding is phenomenally well done and the material is unlike anything I have seen before. It is not at all like the plastic used in any other endbell. It is rock hard.
#408
Sweet.
#409
are we ever going to see them in stores, its seems like they just keep pushing it back more and more
#410
The motors are assembled and just waiting for the packaging right now. You should see the first batch shipped to Great Planes next week.
#411
Great Plains is expecting them the 28th.
#413
cant wait to start running checkpoint 19 turns. I won't half to cut my moter every 3 runs
#414
Here is some info regarding the molded endbells vs. aluminum that Curtis posted in his DC thread--
"the plastic endbells are for the OEM mods and upcoming spec motors to be released by Checkpoint.
The decision of using plastic endbells on the OEM mods was strictly a cost issue. Steve said he couldn’t manufacturer the Al endbells cheap enough to compete in the OEM market............................................ ...So far our testing with the plastic endbell has yielded the same operating temperatures as the Al version, 145-165*F….."
#416
Is the 19T spec hand wound or machine wound ?
Thanks.
Thanks.
#417
Machine wound.
Fixed timing.
Money
Fixed timing.
Money
#418
Must be high demand in the US
#419
I tested run the 8x2 today at 1:9.08 under hot weather.
Performance is good and can last for more than 6min with IB3800 cells. The motor is not very hot after run. 3 packs down the road and the performance is still there without a single touch on the motor.
It is great !
I will order the gold and silver spring to play with ... hope to test my 8x1 next time.
Ernest
It is great !
Ernest
Originally Posted by ernestf
Hi Daryl and all -
I got a 8x1 and 8x2 (with old plastic end bell) on 6 cells touring with rubber tires.
I am running on out door / hot weather (air temp from 30-35C degree).
What is the recommended final gear ratio ?
Thank you very much
Thank you very much
#420
It is great !
Ernest
It is great !
Ernest
I live in Jakarta, tropical weather, 31C - 34C, most of us here use 8.20 final ratio for Reedy Ti & Pt and V2 motors.
