New VBC Flash-04 F1
#212
the f104 front end will also fit on this car just in case the oem front breaks and there aren't any parts available.
#217
I must apologize to all the Flash-04 owners for my dismal showing at RROC last May. Running a brand new car and switching from Futaba to Spektrum bit me so hard in the arse, its not the way i wanted to represent. The car was sooooo twitchy on power, it was nearly impossible to drive anywhere. Now, nearly 2 months later it turns out that the steering exponential on the Spektrum radios are configured opposite from what I consider to be the correct functionality for exponential. So long story short... I kept going in the negative setting direction to slow down the initial steering input which in fact was making it faster, not slower. I should have caught this on day 1 but I didn't. I honestly think I could have made the podium based on how well the car drives now. I'm loving it now that i know what the "real" problem was and everyone comments on how good it looks on the track. We are racing on a very bumpy parking lot track sprayed with soda and the car is now on rails... Finally!
I'm glad I didn't give up on this one.
#218
#219
Silver springs in front
Gold springs on the sides
10.5lb (soft KFactory) spring in the middle with 40w AE oil and 3 hole kit piston.
Ride F1 and R1 premount tires from Thunder Power (full sauce).
5mm ride height all around.
Speedo mounted in the middle as far back as I can get it.
Shorty battery far back against the speedo.
Kit settings for front upper arm with -1.5* camber.
McLaren MP5 body and wings. (I'd like to try something more race proven rather than scale in the future)
Diff set with just a touch slip from a dead stop at WOT (it would be nice to have a way to measure diff tension accurately rather than by feel)
You will likely need about -30% ST EXPO or in my case +30 since I have a Spektrum DX3R Pro.
If I forgot something, let me know and I will elaborate.
#220
Well, here is what I have at the moment:
2-How much droop in rear?
3-Toe out?
4-Caster?
5-What motor...13.5, 17.5, 21.5, etc?
6-What gearing.....pinion & spur with above motor selection?
7-Boosted or Blinkie?
8-Tire sauce used?
#221
HenryC- I take it you will be at superior this weekend?I've got both Foams and rubber tires and a variety of tire tractions.I know you won't have the foams I've got (GQ Tires) and as for rubber break them in first.I tried Pardus but did not break them in and had problems. Now that they are broken in they work good. I"ll be glad to help you out the best I can. Just look fo Team BullFrog I'm easy to spot.
#222
#224
1-How much droop in front? maybe 0.5mm
2-How much droop in rear? 2mm
3-Toe out? )0.5 to 1 degree
4-Caster? Stock setting (both shims in front)
5-What motor...13.5, 17.5, 21.5, etc? Reedy Sonic Mach2 21.5t with 12.2mm RPM rotor
6-What gearing.....pinion & spur with above motor selection? 88/36
7-Boosted or Blinkie? Blinky per UF1 rules
8-Tire sauce used? Paragon 2
See answers in orange above...
