Tamiya XV-01
#1801
My mistake. It's part J6, from the parts tree with the plastic servo saver on it.
I don't have any of the XV-01 parts trees anymore -- I've disassembled them all -- so I have to look at the XV-01 manual and pictures of the parts trees online. It's surprisingly difficult to find pictures of the parts trees intact and large enough to see the individual parts clearly.
#1802
#1803
I got the parts over the weekend. Indeed it is the J6 part that is the adapter. It fit in the 64t spur with no problem, this means, that the gearing with the slipper clutch go much lower. I am not sure what is the biggest pinion that could fit in this configuration, but I can imagine it could easily go up to 33t and give you a 5ish fdr (that is what I like for my local track). I also got some new tires and see how it feels driving the car in higher speeds onroad. Should be fun.
#1805
#1806
If you use a small-enough spur, yes. I'm using a 40t pinion gear and a Kawada 65t spur gear in one of my XV-01s, but I had to grind the inside of the gear cover to make the larger pinion fit, and I had to send the slipper clutch plates to a machinist for modification. A Kimbrough 66t 48p spur should fit without any modifications, but you will need some Traxxas "friction pegs" from the T-Maxx to fill the holes in the Kimbrough spur gear, to make the slipper clutch work.
#1807
Edit: It looks like the biggest they make is a 48p 35t pinion.
#1808
Ideally I would like to not do any modifications at all. The 64t tamiya spur works fine in both terms of room and also with fitting the slipper and pressure plates. Obviously it is a tad smaller than the stock spur, so it could be that the 38t pinion should work, but I guess that would be another trial-and-error test. I currently do not have the funds or a scenario that would justify gearing that car so low but it would still be cool to find out. Heck, I do not even know if Tamiya even makes such a big mod 0,6/ 48dp pinion.
#1809
I know it is not. The stock spur is 0.6 mod and the slipper clutch compatible spur is 48p. They are very similar in size, (the spurs not the module/teeth) so they should be able to fit similar size pinion gears. Lets see how many people this will confuse...
#1811
I do not know if you guys are aware, but Tamiya is re-releasing the XV-01 TC pro again. No changes but it is good to see it available (Nov)
#1813
Good News
#1814
Interesting. The XV-01TC uses a special-length shaft in the front shocks (30.5mm instead of 28mm) that is very difficult to find. I've bought several sets from all over the world so I can use TRF shocks in my HPI RS4s. I wonder if Tamiya is bringing back the XV-01TC with the original front shock setup, or if they've adjusted it to use normal 28mm shafts front and rear?
