Kyosho Touring Car
#1261
foam
Originally Posted by aaron_buran
I was impressed last night on foams, Seaball I think we have a good starting point on the setup now, thanks for all the help. It seems like the alum upgrades fixed our tweaking problem. I think once I get some 6 degree castor blocks, we can make it even better.
#1262
In general the car didn't steer as much as we would like. We changed alot of things throughout the evening that made the car steer more without making it hard to drive. Almost all of the guys running x-ray's and RDX's are running 6 degree castor blocks, of which we don't have at the moment, so I am going to try running some other plastic on the car.
What I was impressed with is how balanced and stable car was even after we made the changes. The last x-ray I had was an FK05, and I always felt like the setup sweet spot was very narrow, whereas on this car it seems to be much wider.
I'll post some setup info in the coming weeks, I'd like to get the car closer to the pace of Herrmann and Goetz before getting too excited. We have a club race next Saturday, I'll post my findings ASAP.
#1263
car
I have ZX5 caster blocks they work but the are a bit taller than the stock 1's abuot 1 to 1 1/2 mm they come in 4 6 8 and 10 deg I think + they are Alum give them a try what I found with rubber if u got to A A in the front and F F in,in the back of the front 2 sus blocks u have a TON of on power streering! so much the car will chatter and in very EZ to drive...let me know how u do..
#1264
Buying a Stallion
Thinking of buying a Stallion. I have a SD TF-5, and so far its been great. However, I'd prefer the Stallion since I run modified, and love the simplicity and easy maintance and quietess of BD's. Now, can I use the front and rear arms, c-hubs, steering blocks, drive shafts/CVD's? If so it I'll take the ones from the TF-5 SD and save a lot of time building the Stallion.
Another question- is there red aluminum diff outdrives for the TF-5 SD?
#1265
#1266
I think the cvd's are the same. I will check for you later. Everything else on the car is the same, except for the drivetrain. Diff and thrust rings are the same
I did see some aluminum outdrives for the SD somewhere. I know the zx5 steel outdrives will work. I've never had a problem with the plastic ones, but I've only been running stock with the SD.
#1268
#1269
can anyone give me a bit of info about the tfo5 i have seen it around on the web but i wanna knoiw wat its like mto drive any help
#1270
Customworks -
We are running some arm sweep in the front of the car, not that much though...
Do you have part numbers for those alum castor blocks?
Thx,
-A
Thx,
-A
#1272
Customworks -
Thx,
-A
Thx,
-A
www.pnracing.com
#1274
Oh, I thought you said they did work, my bad.
Well back to the drawing board, I am going to use some other OEM's plastic on the car.
Stay tuned.
-A
Stay tuned.
-A
#1275
Hey Arron give me a call at the shop.
