the fan for TC motor
#18
Registered User
#19
Tornado has my vote. Running off of receiver is more than enough cooling. Like a previous poster said watching that youtube video sold me. Untill I see either brands doing a video actually showing what a 25mm or 30mm fan can do, I will stick with the Tornado.
#20
Find a distributor in the US for these;
http://www.nmbtc.com/fans/part-numbe...L-01W-B50/4966
Shouldn't be that difficult, or expensive.
8.1cfm at 5V
8.1cfm at 5V
#21
I run it off the receiver which is 6V.
Everytime someone has pointed out how much air their fan shifts I just show them the NMB fan and they realise they wasted their money
If you can find a decent dist. instead of a model shop etc it should be pretty cheap (less than half the cost of a Much More fan here)
#22
#23
Look on the bulkhead, there is a tapped screw hole spare behind the motor. Put a grub screw in here and then attach a servo post to it.
Fix the fan to the post and you will have the best possible fixing for your fan. Incredibly neat, tidy, strong and light!
#25
Never tried it off the battery due to being 5V.
#27
It will also shift a hell of a lot more air than any 25mm fan.
But if a 25mm is easier to fit for you then fine.
Skiddins
P.S. I meant less than half the price of Much More's 40mm fan, not 25mm
#29
Hello guys,
I got myself two strong 40mm fans to cool down my boosted 10.5t motor in the coming summer races. I plan to put one in front and one behind the motor. Now I am unsure how I should direct the airflow to the motor. Normally I have one fan blowing air towards the motor.
(ignore the motortype)
Do you think it will be more effective to have one fan blow and the other suck the air (away from motor in direction of travel) or to have both blowing towards the motor?
