Xray T4 '13
Old 10-24-2012, 12:59 AM
  #961
B00t13g's Avatar
Originally Posted by RCknight View Post
Looking at the T4 steering rack, would it be possible to flip the rack around, and have the arms lower and put he rack on top so I would like to avoid the steering limitation? Looking at it though I think might need shorter posts. I would like to mount it similar to BD7.
You should buy a bd7!
B00t13g is offline
Old 10-24-2012, 01:29 AM
  #962
RCknight's Avatar
No, I don't want to buy rubber hex wrenches, a padded pit table and bubble wrap my car.
RCknight is offline
Old 10-24-2012, 01:39 AM
  #963
Tbh though, there is plenty of steering on the t4, didn't see anyone go on the inside of me or any other t4 drivers at the big meet I had on Sunday.
Mb3195 is offline
Old 10-24-2012, 02:07 AM
  #964
RCknight's Avatar
Naa..it's more of a perfectionist and logic thing with me. It's all good, but when I think logic design I first would think, mount the heaviest part of the steering components being the optional aluminum steering arms low as possible, thus reducing weight by making the steering posts shorter, putting the rack higher, thus not needing three shims, making easier access to the rack screws from above, and not limiting the steering throw.
RCknight is offline
Old 10-24-2012, 02:13 AM
  #965
defcone's Avatar
Trader Rating: 15 (100%+)
yep. Ride height is more like 7mm without it.
What modification was made?
defcone is offline
Old 10-24-2012, 02:25 AM
  #966
First you need to shorten the bottom ball cups by .5mm, unscrew the top collar and remove the O ring then bore out the top of the collar to 15mm this then allows the collar to ride 2mm up and over the shock cap (14.8mm dia) You can still put the O ring back in to use with the shorter springs.
If you look close at the pics you can see the screw collar about 2.5mm higher than standard.
Bb
bucketboy is offline
Old 10-24-2012, 02:28 AM
  #967
Skiddins's Avatar
Probably not, If the arms are the wrong way up now, the link to the servo hits the top deck as there isn't enough room.
If you were to mount everything very low it will all start to foul on the belt.
Better off working on a setup to give you more steering.
Skiddins
P.S. don't bother with aluminium arms, just adding more unnecessary weight
Skiddins is offline
Old 10-24-2012, 02:33 AM
  #968
defcone's Avatar
Bb
Have you thought of using lowered retainers?lol
defcone is offline
Old 10-24-2012, 02:49 AM
  #969
Yeah, I could easy make some but you would then need to grind away at the wishbone to get them to fit, only takes 5mins to alter the screw collars, only real alteration between kit and mod is the shortening of the ball cup by .5 mm
I could do an easier fix and buy a new set of shorter springs
Bb
Old 10-24-2012, 02:54 AM
  #970
you still wouldn't be able to get the ride height low enough by doing this.
Mb3195 is offline
Old 10-24-2012, 03:11 AM
  #971
RCknight's Avatar
Yeah, again personal preference, after looking at it again, I think all you would have to do is create shorter steering posts. If you flip the arms around and put the rack on top you have more than enough belt clearance. It hard to eye ball it, since I don't have my car yet. I've already order the aluminum arms. I broke too many plastic ones on my 12. Waiting for the new motor mount, pivot ball block and it will be a thing of absolute beauty. I think I'll call her Betty.
Skiddins
RCknight is offline
Old 10-24-2012, 03:17 AM
  #972
Sam9's Avatar
Originally Posted by Dan View Post
Man, this thread is already at nearly 1000 posts and only a handful of people have gotten theirs on this forum...
Waiting badly for my car to start shipping!
And more then half is nonsense and people whining about not getting the car yet. To get to the gold posts I have to dig through all the crap posts. Just wait god damn it...
Sam9 is offline
Old 10-24-2012, 03:48 AM
  #973
Skiddins's Avatar
Don't worry, soon everyone will have theirs and it will be 'normal service is resumed'
Skiddins is offline
Old 10-24-2012, 04:11 AM
  #974
I should have mine tomorrow or friday... WOOOOO
d.k.vmatt is offline
Old 10-24-2012, 05:43 AM
  #975
XSLR8's Avatar
Got mine today in Australia.
Thanks R.A.B Hobbies.
XSLR8 is offline
