Like Tree2Likes
Xray T4 '13
Old 09-16-2013, 08:13 PM
  #4891
Adam B's Avatar
Sorry, but I am not sure what you mean by "wears out". Are you referring to the actual material breaking down, like maybe hard arms turn to medium arms over time?
Adam B is offline
Old 09-16-2013, 09:11 PM
  #4892
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Like developing slop.
Dan is offline
Old 09-16-2013, 09:31 PM
  #4893
Adam B's Avatar
I have yet to test graphite arms, but the hard & medium arm seem to last a long time. I do use a 3mm reamer on the arms and polish the pins to an almost mirror finish.
Adam B is offline
Old 09-17-2013, 01:42 AM
  #4894
Skiddins's Avatar
Originally Posted by Dan
Anyone? Or is it better just to get new stock arms.
The kit items take a long time to develop any slop, the graphite arms are supposed to change the handling.
I wouldn't change them just to make them last longer, change them because you want to change the setup.
Only problem I found with the graphite, is that when I tried to remove the roll bar drop links from them I broke one of the 'pivot balls' that form part of the wishbone.
Skiddins
Skiddins is offline
Old 09-17-2013, 02:32 AM
  #4895
Skiddins
How do the graphite arms handle in comparison to stock ones?
Regards,
David
niemand is offline
Old 09-17-2013, 02:55 AM
  #4896
Bishop's Avatar
My T4 came with graphite arms on it, I'd say they feel very sharp and highly responsive, I want say they may even weigh a bit less, but I'm not sure on the T4, I do know though you will sacrifice some strength, most graphite things tend to more brittle, so they likely won't take a hit like the plastics will.
Bishop is offline
Old 09-17-2013, 07:08 AM
  #4897
Is there any word on the official release date of T4 2014.
Joe DiGirolamo
losi888 is offline
Old 09-17-2013, 07:36 AM
  #4898
Skiddins's Avatar
Joe DiGirolamo
No
Skiddins is offline
Old 09-17-2013, 08:01 AM
  #4899
Dan
Dan's Avatar
Thanks guys, definitely wanting to add a bit more response as well along with the graphite arms. I haven't broken anything since buying it new last year. Just going to do a full rebuild of the suspension to tighten it all up again as if it was new.
Dan is offline
Old 09-17-2013, 08:26 AM
  #4900
CristianTabush's Avatar
Actually, RC America has told us that they expect them some time in October, I would venture out and say that in the second half of the month. We are going to start a pre order for them today as well as the X12 2014, which is only a week or two away.
Being in Texas, we will be one of the first shops to get them
CristianTabush is offline
Old 09-17-2013, 08:35 AM
  #4901
Originally Posted by Xpress
Panaracer gears fit fine, but the tooth area is thicker than the Xray gears. The belts run pretty close to the teeth. The center of the gear is actually a little thinner than the kit gears. I put a .1mm shim over each screw hole before pressing the gear on the layshaft otherwise the pulley on the screw side will have a little bit of a gap between the spacer and e-clip.
I probably wouldn't buy them again, but I bought 3 of them and am just making use of them.
Thanks a lot for your feedback.
Manson is offline
Old 09-18-2013, 01:53 PM
  #4902
I've been using graphite front arms for around 4 months now and I love em!
In my humble opion, I feel I get a better response from the car, feels more precise and just sharper and quicker all around.
I have not broken one, but I imagine they are weaker than the standard arms.
Andrew S is offline
Old 09-19-2013, 03:09 AM
  #4903
MrRolla's Avatar
Trader Rating: 30 (100%+)
Joe DiGirolamo
We are expecting them around the 14th of Oct from our distributor in Australia so obviously europe and America before us
MrRolla is offline
Old 09-19-2013, 05:35 AM
  #4904
Hey all: I recently bought a used T4 and I am combing through it now. The front belt feels too tight (and has since I bought it). I've rotated the cam to try to give it as much slack as possible but it goes from very taut to still tight. I cleaned the gunk out of the pulleys so I don't think it's that. Please post some ideas if you've got any - I'd really appreciate it
Pipe Killer is offline
Old 09-19-2013, 05:41 AM
  #4905
Wrong belt (shorter) ?
305432 HIGH-PERFORMANCE KEVLAR DRIVE BELT FRONT 3 x 513 MM
305431 HIGH-PERFORMANCE KEVLAR DRIVE BELT FRONT 3 x 507 MM
TeemuS is offline
