Xray T4 '13
#4022
#4024
Thanks for the replies, gives me an insight as to what could break.
It will be interesting findings getting a good setup on foam after using a 415 for about four seasons!
I think it will be a question of asking local T3 guys what their setup is and going from there...
Does any gear oil come with the kit?
#4025
#4026
i was told that my car is "stopping" in the corners,whats the best way to deal with this?,would i be right in just standing up the shocks more and reducing rear droop,my son runs blinky with a tc6 and i cured it quite a bit by going stiffer on the springs and standing up the shocks,but the tc6 is a much stiffer car,just want to hear your approach to it,and should the front feel softer than the rear?thanks in advance
#4028
#4029
#4030
Thanks for the info! I agree that hooking up with a local track is key. Looks like 17.5 blinky is the popular class with Solaris med tires. So much to learn with this class!
#4031
If you are running the kit springs that could be the problem, I felt my car was doing the same, talked to a couple of the top UK XRay drivers and they suggested changing the progessive springs to linear, made a bring difference car felt a lot better, now running 2.7 front & rear.
#4032
i have another question,i have a spare set of 52mm standard driveshafts from the front when i changed to the ecs shafts,if i put the 52 mm in the rear and remove the alloy 50mm what can i expect to happen,i understand at the front that the 50mm make the car more aggressive but not sure what happens to the rear when made longer,im not good enough yet to feel the difference hence the question,cheers
#4033
A few fast guys at our track use the -0.75 front roll center suspension blocks, 2.7 f/2.5R linear springs, with 30wt to 35wt shock oil. Different feel and driving technique, but it's worked well. Would keep trying different small adjustments to meet driver preference and track requirements.
#4034
Because the rear track is narrower on the T4 and the outputs from the gear diff are slightly wider than on their older cars the driveshafts had to be reduced to the 50mm variant.
You can get them to fit but you'd have to widen the rear track by a few mm which would probably ruin the handling.
Skiddins
#4035
