Like Tree2Likes
Xray T4 '13
Old 01-01-2013, 10:13 PM
  #2146
B00t13g's Avatar
How far forward is everyone mounting their bodies or are you putting them right on the bumper?
B00t13g is offline
Old 01-01-2013, 10:57 PM
  #2147
Trader Rating: 23 (100%+)
3mm off the bumper.
pcar951 is offline
Old 01-02-2013, 08:19 AM
  #2148
MikeXray's Avatar
Trader Rating: 73 (100%+)
If you mount the body forward, it really helps to pad out the bumper with foam, the less flex the front end has, the longer the wheel wells last.
MikeXray is offline
Old 01-02-2013, 09:33 AM
  #2149
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
Not sure if this is the preferred method . But I mount my body as far back as I can this way my wing is supported better and still acts like I moved my wing back so I have more rear down force for the high-speed sweeper..
I also cut a custom foam bumper and shape it to body so it helps with corner impacts .
And I also added a 5th body mount on top of one of the steering posts . I can make a body last 1000 wrecks with very little cracks In front fender area.
jlfx car audio is offline
Old 01-02-2013, 10:23 AM
  #2150
Suspended
Justin, we mount the bodies further forward for the extra steering that it gives. I cant remember the last time I mounted my body against the bumper.
Chris Adams is offline
Old 01-02-2013, 11:12 AM
  #2151
Never thought of it like that . Might try that some time when I need more steering. Tks
Old 01-02-2013, 11:18 AM
  #2152
Will say tho my foam bumper is bigger than stock ( goes further out than stock bumper .
I've never cut the wheel out forward of the indent.
Old 01-02-2013, 11:31 AM
  #2153
MikeXray's Avatar
This is preference, I can say that running mostly 17.5 and some 13.5, I never have a car that is loose in a sweeper, usually looking for steering.
MikeXray is offline
Old 01-02-2013, 02:50 PM
  #2154
hello
have you tried new team cso spring
greetings
txili is offline
Old 01-02-2013, 05:06 PM
  #2155
Adam B's Avatar
Default Opinion Please....
What is the "slowest" mod motor that is respected among racers in that class? I know of somebody that bragged about being TQ and winning with a 10.5, which is a modified motor, technically. Just wondering what people in a modified class feel is modified.
Adam B is offline
Old 01-02-2013, 05:13 PM
  #2156
erchn's Avatar
My opinion is that it's all relative to the track on which you are running. On a small tight track a 10.5 might be fine, slightly bigger a boosted 10.5 might be fine. On a large track, where you run 1/8th scale machines also, a 5.5 boosted would probably be about the minimum.
When boosting is involved you can get away with higher winds very easily.
That said, slowest is only slow when you aren't winning.
erchn is offline
Old 01-02-2013, 06:17 PM
  #2157
The term "Mod" is really just a carryover from brushed motors where Spec motor design was more restricted than it is now.
e.g. 27T and 19T had fixed timing, wire diameter and length.
10.5T is regarded as a stock motor but is normally very similar to the lower winds in the same range.
cyclonetog is offline
Old 01-02-2013, 06:22 PM
  #2158
kuruption's Avatar
Trader Rating: 24 (100%+)
ROAR considers 10.5 as "super stock." (but that's ROAR, don't know about other sanctioning bodies). I know Trinity labels 10.5 as stock too.
10.5 w/ a good boosted ESC could be extremely competitive with 8.5s and 7.5s.... maybe even 6.5s...
kuruption is offline
Old 01-02-2013, 07:53 PM
  #2159
artwork's Avatar
Trader Rating: 88 (100%+)
Actually 10.5 or lower is considered modified. 13.5 is super stock and 17.5 is stock according to Roar rules.
artwork is offline
Old 01-02-2013, 08:06 PM
  #2160
kuruption's Avatar
You're right... there's a bit of confusion in the rulebook, but it appears 10.5 is a spec, modified motor.
