Team CRC Xti 1/12th Scale!!
#1983
I, and several other CRC drivers, run the standoffs because they add rigidity between the chassis and the tweak plate. The plastic ones sometimes will flex a little when you use the included o-ring to hold the battery down whereas the aluminum ones won't flex at all. For a cheap part they are worth it in my opinion.
Your front width is fine but I would suggest spacing the rear out to 171-172mm. You will need a couple shims on each side to get there. What this will do is add rear end stability for you. It will almost feel like you have more grip but at the same time be a little bit smoother.
#1986
XTI WC spur
Does anyone know what the size spur comes with the XTI WC kit? Thanks
#1988
Are there any news when the next generation of the CRC chassis will appear? The prototype was already on the track at the WC in Japan.
#1989
Xti wc
Which front arm top plate for the wc? Short or long? 3276 or 3278
#1992
Thanks to all of those that helped with setup tips and tire tips for my xti ae,car runs much much better now,will be back to ask more questions .
#1993
Hello,quick question about steering link angels,is it better to raise the steering ball up to level the rod or lower the servo saver point so they r straight and level with the chassis,the rods have a very slight reward rake to them to the ball cup on the steering blocks,as if I was looking down on the front end.I read this is what u want with the links.I also think this is what is causing the bump steer,it bumps to toe in as the suspension is compressed.I also believe this is one of the reasons the car has a slight push on the corner exit.So do i lower the servo saver points or raise the the ball stud on the steering block to help cure this bump toe in problem??Sorry for the rant,lol.Thanks a lot for the help.Erik
#1994
Looking for a new car for the indoor season and would like to see some info on the new car coming out.
#1995
